20 Most Recent 4Button Remote 474P Questions & Answers
What's the valet button on python 474p
The Python 474p remote control has a valet button, also known as a valet/program switch. Function of the Valet Button:
  • Programming Remotes: The valet button is crucial for programming new or replacement remote transmitters to the Python 474p system.
  • Emergency Override: It can be used to perform an emergency override of the system, potentially bypassing the starter kill function.
  • Entering/Exiting Valet Mode: You can use the valet button to place the system in Valet Mode. This disables security features like the alarm, allowing the vehicle to be serviced or washed without triggering the alarm.
  • Channel Selection for Programming: During the programming process, you press the valet button a specific number of times to select the function (channel) you want to program to a specific button on the remote. For example:
    • Pressing once selects Channel 1 (Arm/Disarm/Panic).
    • Pressing twice selects Channel 2 (Silent Mode/Remote Valet/Trunk Release).
    • Pressing three times selects Channel 3 (Remote Start or other accessories).
Location: The valet button is typically located under the driver's dashboard or driver's kick panel, and is plugged into the system's main control unit. Note: The exact location might vary depending on the specific vehicle installation. In summary, the valet button on the Python 474p serves as a crucial interface for programming the remote control, entering/exiting valet mode, and performing emergency overrides.
6/26/2025 3:39:48 AM • 4Button Remote... • Answered on Jun 26, 2025
How to program/use Valet 474P 3-button remote start fob
Not sure about the rest but doors unlocking and then relocking is a sign of a flat battery in the remote.
12/2/2022 12:03:40 AM • 4Button Remote... • Answered on Dec 02, 2022
Need to reset my python remote starter 474P
I got this free Pdf manual from an online store for free and I don't think Ive visited a mechanic or fixya for help for more than 3-4 times out of the all the times I fixed the chipper in these 4 years
1/30/2019 9:31:02 AM • 4Button Remote... • Answered on Jan 30, 2019
Remote wont start 09 mustang without havinga key in ignition. Did befor i changed fuse for acc under hood
hello u'd need a proper manual for this in my opinion like there are plenty of dealers and online shops that deal in those.. you can get some free at sites reliable-store. and it;s actually really illustrative
1/25/2019 4:02:44 PM • 4Button Remote... • Answered on Jan 25, 2019
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is: 1. Enter car - Leave door open. 2. Turn key to "on" position. 3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7) 4. Watch alarm light - It should now flash 7 times. 5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp" 6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button. 7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
9/1/2017 5:59:03 PM • 4Button Remote... • Answered on Sep 01, 2017
Key fob not working well
Fob my be bad try other fob if that one works replace bad one.
4/30/2014 4:38:32 PM • 4Button Remote... • Answered on Apr 30, 2014
manual
Remote locks don't work
no, that is a switch to detect the hood being opened. The valet switch is a small button or switch and could be anywhere inside the car. Most installers place them near the driver. Check in the center console, around the drivers side kick panel, under the dash, etc.
1/21/2014 1:17:37 PM • 4Button Remote... • Answered on Jan 21, 2014
Python 581xp
Here you are; https://www.manualslib.com/manual/545517/Python-581xp.html
9/1/2024 9:18:54 AM • Python Vehicle... • Answered on Sep 01, 2024
3answers
How do you get the batterie out of a python
Cut it in half and remove the battery it swallowed. The python will likely either bite you or die, however.
7/31/2024 6:29:50 AM • Python Vehicle... • Answered on Jul 31, 2024
2answers
How to reset python remote starter
hello u will find a lot of wiring diagrams and circuit diagrams help books and stuff like this .. im a frequent buyer there since Im a mechanic so take help from there
12/30/2023 11:50:48 AM • Python Vehicle... • Answered on Dec 30, 2023
3answers
Snakes that twist around branches
If you are in the south part of the US, especially if it is around a pecan tree, would suspect it to be a copperhead. At night they like to climb trees and eat insects that also hang out around trees. They blend in very well and starting at dusk, you might want to avoid the base of trees. A rattlesnake also will climb a tree especially if they just ate a rat or something. Have had them drop down on me while walking under a tree.
5/20/2019 6:05:10 AM • Python Vehicle... • Answered on May 20, 2019
4Button Remote 474P Logo
27 questions posted
Top Python Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Jonathan Buck
Jonathan Buck
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
View Most Popular
  • Python Vehicle Parts & Accessories
Most Popular Question
valet button python 474p
  • Vehicle Parts & Accessories
