Python 7752p Replacement Car Alarm Remote 991 951 Logo
Posted on Jul 15, 2011
Hi, how do I set the time on my python 7752p remote?
Python remote start
I'm not positive, but I'd bet your remote has an issue with electronics, or it could be as easy as the battery in your remote
Thanks, Terry
Set up the car remote
A 7701P is a remote transmitter. It is not an alarm. You must know the alarm's model because different models have various ways of programming transmitters. In other words, you do not program the 7701P. The frequency is already fixed. You must program your security system to teach it that transmitter's code. Look up the manual for your security system. Instructions will be there. This typically involves turning the ignition on/off a specific number of times and pressing a valet/programming button (or switch) a certain number of times and then pressing a button on the transmitter.
4helpful
How to reprogram Python 4Button Remote 474P ?
I had the exact same thing happen with my 4-button 474p remote. WITHOUT REMOTE START the correct sequence is:
1. Enter car - Leave door open.
2. Turn key to "on" position.
3. Within 5 (five) seconds press the Valet button 7 times then hold down. (Programs to channel 7)
4. Watch alarm light - It should now flash 7 times.
5. While still holding down the Valet button - Press the "lock" button on the remote and release. Should get a "chirp"
6. Now release and repress the Valet button once, holding down. You'll get the "chirp". Release Valet button.
7. Turn key "off". Exit vehicle and test remote. All 4 buttons should now work.
A few times each week when i use the remote start function on my Python 991, the truck will start for a second or two then the horn starts blowing, lights flash then the truck shuts off and I lose all...
It sounds like the factory alarm is setting up. To make sure the factory alarm does not come on you should make sure all doors are closed before you actually hit the remote to lock the doors. Do not lock the doors with the switch on the door. Make sure you use the Python remote only and all doors closed before you press the lock button.
1helpful
How to turn light on the python 990 remote?
If you just want the LCD backlit turned on, press and hold the program button on the back of the remote until the remote gives a long tone, that indicates that you've entered programming mode. Then within 5 seconds of entering programming mode press the the unlock button. The remote will beep once for backlight on and twice for backlight off. In the "on" setting your backlight will turn on each time a button on the remote is pressed. It will run down your battery faster though. It's the same for both the 990 and the 950 remotes.
2way remote for Python 872 not working
Make sure that the responder is set for your car. this responder can work for multiple cars...The owners manual tells you how to check.
1helpful
Reprogram python 990 remote
The P stands for programming. It's used when setting up the alarm system, you would need the manual for the system to tell you what can be done. I have a Python 990 and I can change pretty much everything from sensor adjustments, amount of time it turns over for starting, disabling the siren and many other settings. I found out the hard way one time when I accidentally pressed it and turned the key off and it disabled the siren. I think that's how it happened, been a while since it happened. I would have to get the manual out to be exact. You can also do the programming by pressing all 4 buttons at once and hold for 2 seconds. But you still need the manual to know what your doing. Hope this helps
Top Python Home Security Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Python Home Security Expert? Answer questions, earn points and help others
