Hello thanks for using fixya
To solve it First try this:
If not try the next step
Also do you have any kind of data equipment like a camera connected, if
so this could be causing the problem as well. Unplug it if so and see if
this is the problem after the above steps
I hope this helps, because Canon doesn't even have support for an error code
6500.
If it all fails the final & best option is to take it back where you purchased it or contact Canon service center
about the error code. They will surely solve it.
I hope this solution will helpful 4 u
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
