Canon PIXMA MP830 All-In-One InkJet Printer Logo
Posted on Dec 28, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code 6500
Canon Printer, Error code 6500 ?
Anonymous
Level 3:
President:
  • Master 2,306 Answers
  • Posted on Dec 28, 2009
Anonymous
Master
Level 3:
President:
Answers
2306
Questions
Helped
1143430
Points
8734
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
5 Related Answers
Mukesh Kumar
  • 3230 Answers
  • Posted on Oct 01, 2009
SOURCE: error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
Anonymous
  • 787 Answers
  • Posted on Oct 10, 2009
SOURCE: my canon mp830 had an error code 6500. I turned it
The 6500 error code is a logic board error code. Sounds like it needs new logic board assembly.
Testimonial: "Thank you cene765. I think my next printer will be an HP."
Anonymous
  • 37 Answers
  • Posted on Jun 08, 2008
SOURCE: Canon PIXMA MP450
An Error Message Is Displayed On The LCD title-bar.gif If an error message is displayed on the LCD, take the corresponding countermeasure described below.
Message
Action
There are no photos in memory card.
There are only invalid images on the memory card.
Photo data edited/processed on a computer should be printed from the computer, not from the camera.
There is no paper.
Reload the paper correctly and press [OK].
The paper is jammed.
If paper has jammed in the machine, clear the jam, reload the paper in the machine correctly and then press [OK].
Ink has run out.
U041
Replace the FINE Cartridge, and close the Scanning Unit.
If printing is not finished yet, just press [OK] on the machine to continue printing in the "no ink" state.
Replace the FINE Cartridge with a new one as soon as possible after printing finishes. The machine may be damaged if printing is continued under the ink out condition.
The following ink cartridge cannot be recognized.
U051
U052
U053
U059
The FINE Cartridge may not be installed properly, or the Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Some ink cartridges are not installed in place.
U075
U076
Confirm that the FINE Cartridges are installed in the appropriate positions.
The ink absorber is almost full. Press [OK] to continue printing. Contact the service center.
The ink absorber is almost full. Printing will no longer be possible once the ink absorber is full. Contact the service center immediately. Press [OK] to continue printing.
Incompatible device detected.
Depending on the model or brand of your device, you may have to select a print mode compliant with PictBridge before connecting the device.
You may also have to turn ON the device or select Play mode manually after connecting the device to the machine. Perform the necessary operations according to the instruction manual supplied with your device.
If the error is still unresolved, there is a possibility that you are using a digital camera or digital video camcorder that is not supported by this machine. Use a digital cameras or digital video camcorder compatible with this machine.
Auto head align has failed.
Make sure all required boxes on the head alignment sheet are filled in, and that the sheet is set in the correct position and orientation on the Platen Glass.
If the machine is connected to the computer, you can align the FINE Cartridge using the MP Driver. Follow the procedures described in the Printer Driver Guide.
The following ink may have run out.
U162
This FINE Cartridge may have previously been used, or the ink may have run out. The function for detecting the remaining ink level will be disabled since the remaining ink level cannot be correctly detected. If you want to continue printing without this function, press [OK]. Canon recommends to use new genuine Canon Cartridges in order to obtain optimum qualities.
U140
The FINE Cartridge may not be the compatible with this machine. Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the FINE Cartridge Alignment.
Printer error.
An error requiring servicing might have occurred. Turn OFF the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn ON the machine. If the same error occurs, contact a Canon service representative.
Anonymous
  • 837 Answers
  • Posted on Dec 06, 2008
SOURCE: my printer has the error
Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
If you want to take the time to try and repair it, you can take the unit apart and search for a loose connection, or unplug and replug all connections. Other than that, you should consider buying a new printer
Anonymous
  • 812 Answers
  • Posted on Apr 06, 2010
SOURCE: canon MP530
Hey welcome to fixya. Hope u 'll be fine
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. Solution is first of all you can try to reset your printer -
  • Turn the printer off with the Power button (if available).
  • Disconnect the data cable from the printer.
  • Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
  • Turn the printer back on. If this works you're done,
If it not works then try following
  • After confirming that the printer is powered on, open the paper output tray.
  • Open the top cover and wait until the print head moves to the center.
  • Open the inner cover and check that ink tanks are properly seated.
  • Properly seated
  • Press down on each ink tank until a click is heard.
  • Close the inner cover and top cover
Best of luck
Kindly keep thumbs up in Rating if it is helpful,
THANKS & Keep using Fixya
3answers
Canon pixma iP4200 error code 6500
It sounds like you've taken the correct steps as that error code asks you to reset your printer. And you've already one a factory reset. I would take the printer into geeksquad/bestbuy to have them work on the printer hardware in order to overcome the issue.
Thank you.
Canon mx347 error 6500 Display error code 6500 and alarm lamp flashing
1) Try to reset the printer to manufacturer defaults and chest.
2) main cause with the logic board itself or with other parts in the printer or cartridge.
5helpful
Printer blinking error 6500 help
The error code of 6500 is a PCI bus error and this is a Service Error Code. Typically this is an internal error of one of the ASIC chips on the logic board and can only be repaired by replacing the logic board at the Canon Service Center.
1helpful
I have a cannon mp560 printer and receiving a error 6500
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. I would contact Canon Support to find the closest location to take it to or send it to. Thanks, Rick.
3helpful
Error code 6500
*Error Code - [6500]
*Conditions - The PCI bus error is detected by the ASIC.
*Solution (Replacement of listed parts, which are likely to be faulty) - Logic board ***'y
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you better ask for replacement.
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much a user can do except replacing the malfunctioning hardware.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My canon mp830 printer is saying error 6500 and i cannot get it to do anything, i have un plugged and re plugged and nothing. what does this error code mean?
The service error 6500 refers to "other hardware error". This error results from printer hardware failure & nothing much can user do instead of replacing the malfunctioning hardware. 6500 is generally logic board error code. If the printer is under warranty, you can ask for replacement
Abhilash
$7 is the charge for the service provided.
2helpful
Error 6500 on a Canon MP500
choy ada yg tahu printer canon pixma mp500 error code 6500 g y? please help me
1helpful
Error 6500
The service error 6500 refers to "other hardware error”. This error results from printer hardware failure & nothing much can user do instead of replacing the malfuctioning hardware.
2answers
Canon error code 6500
The PCI bus error is detected by the ASIC. - Logic board problem
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
