resident966 Posted on Sep 23, 2024
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oce PlotWave 350 error code 23503 - OCE Office Equipment & Supplies
Oce Guy
Level 2:
Novelist:
  • OCE Expert 317 Answers
  • Posted on Oct 23, 2024
Oce Guy
OCE Expert
Level 2:
Novelist:
Answers
317
Questions
0
Helped
195933
Points
486
EC 23503 means there may be a problem with the drive motor. in 16 years I've only replaced one. More than likely the motor connector may need to be reseated or cleaned. This motor is difficult to get to and is a PITA to replace so I would recommend calling a certified technician to do this work.
ADMIN Andrew
Level 3:
Top Expert:
  • OCE Master 73,795 Answers
  • Posted on Sep 23, 2024
ADMIN Andrew
OCE Master
Level 3:
Top Expert:
Answers
73795
Questions
Helped
6296028
Points
431460
Despite checking for 20 minutes, there is no mention of this code. The manual simply says this
If an error occurs that you cannot solve, please remember the error code displayed on the user panel and contact the helpdesk for assistance.
https://files.lfpp.csa.canon.com/media/Assets/PDFs/TSS/external/PlotWave340_360/Documentation/Oce_PlotWave_340_360_Operation_Guide_en-GB.pdf
There is no Service Manual for it.. These machines are so specialized, you are stuck.
https://www.google.com/search?q=Oce+PlotWave+350+service+manual
Testimonial: "During printing, the plotter simply stops while the paper remains in the track, an error pops up. He suggests turning off the plotter, after that I take out the paper, the potter loads up and works again for a while. The error frequency is about 30 minutes, that is, every 30 minutes (approximately) the plotter stops and everything repeats."
2answers
Canon Oce Plotwave 360. I have error 'no communication with controller - 95'.
Question edited for clarity
CopyTechNet is the best place to ask, plus Canon Support. This is an unusual machine, a professional quality machine, and very expensive.
https://www.google.com/search?q=Canon+Oce+Plotwave+360+error+no+communication+with+controller+95
2answers
OCE Plotwave 345 error codes 22551(printer) and 22531(printer)
This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
Oce360 plotwave code error 22515 ????
we bought a machine oce plotwave 360 6 month ago wich show error code 22515 and 22550 could you please explain the code
Oce plotwave 350 error code 8507?
Fuser NTC 4. Generally not customer replaceable due to part unavailability. These are ceramic and easily break if not installed correctly and with care. I would recommend an authorized Canon/Oce service representative for parts and service.
What is oce plotwave 350 error code 22701
Initiate conditions failed. More than likely, something was either opened or closed out of sequence. Turn off unit, restart and open up the drawer, then close. Open up the fuser cover then close and open up the manual feed and close and the error should go away. If not, it may be either a switch or a fuser issue. Call an authorized Canon/Oce service representative for parts and service.
2answers
Oce Plotwave 300 8526
08526 Fuser Setpoint not reached. This will require an authorized Oce service technician to check the NTC values, fuser and wiring.
Oce plotwave 350 how do I clear error code 8510?
Fuser NTC 2 failure. Call an authorized Oce representative for parts and service.
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
Top OCE Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Ngoro
Are you an OCE Office Equipment and Supply Expert? Answer questions, earn points and help others
