There is nothing you can do, even if you had the service manual. The first two error codes deal with power supply issues and the last one deals with the fuser section, which may be related to the initial problem of power issues. I would recommend you call an authorized Oce/Canon service representative to determine what exactly the fault is. This printer is a new model, and there is not likely parts available outside of official Oce/Canon logistics.
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
SOURCE: Hi, our oce variolink 2822c
Your machine is made by Konica Minolta. The C3721 code means that your fuser unit has detected an overheat condition. The fuser unit is the assembly that uses heat and pressure to "fuse" the loose toner onto the paper. It is located right where the copies exit the machine. Your are going to need to have your local service company come out and make repairs. You may get advice as to how to reset the code but beware. Since this is an overheat code, if you reset it more than once you can do severe damage to your fuser unit. You may turn a simple and relatively in-expensive repair into a major one.
I would waot if at all possible for the service technician, but I have only worked on Konica Minolta copiers for nearly 28 years now.
Good Luck and Thank You for using Fixya.
WheatlandServices
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
These code means- power supply faulty or you can refix main board connectors.
My no. is-9982309422
+919982309422
