A
Anonymous Posted on Jun 18, 2014
Oce plotwave 350 error code 8507? - Office Equipment & Supplies
Oce Guy
Level 2:
Novelist:
  • Office Equip... Expert 317 Answers
  • Posted on Sep 17, 2021
Oce Guy
Level 2:
Novelist:
Answers
317
Questions
0
Helped
195933
Points
486
Fuser NTC 4. Generally not customer replaceable due to part unavailability. These are ceramic and easily break if not installed correctly and with care. I would recommend an authorized Canon/Oce service representative for parts and service.
4 Related Answers
A
Anonymous
  • Posted on Aug 25, 2008
SOURCE: Oce TDS 400 Printer. Erore Prob.
erore
Anonymous
  • Posted on Aug 01, 2011
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Anonymous
  • Posted on May 24, 2012
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
zenseo1992
Printer Help & Support
  • 783 Answers
  • Posted on May 03, 2013
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
2answers
Canon Oce Plotwave 360. I have error 'no communication with controller - 95'.
Question edited for clarity
CopyTechNet is the best place to ask, plus Canon Support. This is an unusual machine, a professional quality machine, and very expensive.
https://www.google.com/search?q=Canon+Oce+Plotwave+360+error+no+communication+with+controller+95
2answers
OCE Plotwave 345 error codes 22551(printer) and 22531(printer)
This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
Oce360 plotwave code error 22515 ????
we bought a machine oce plotwave 360 6 month ago wich show error code 22515 and 22550 could you please explain the code
Hi i have a problem with oce plotwave 360 give me an error 22552 we change the sd card but still have the error
Hi i have a problem with oce plotwave 360 give me an error (NO COMMUNICATION WITH CONTROLLER - 95) please help me wath i need do
What is oce plotwave 350 error code 22701
Initiate conditions failed. More than likely, something was either opened or closed out of sequence. Turn off unit, restart and open up the drawer, then close. Open up the fuser cover then close and open up the manual feed and close and the error should go away. If not, it may be either a switch or a fuser issue. Call an authorized Canon/Oce service representative for parts and service.
2answers
Oce Plotwave 300 8526
08526 Fuser Setpoint not reached. This will require an authorized Oce service technician to check the NTC values, fuser and wiring.
Oce plotwave 350 how do I clear error code 8510?
Fuser NTC 2 failure. Call an authorized Oce representative for parts and service.
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
