A
Anonymous Posted on Jan 21, 2012
Oce plotwave 300 error code 5703 - Office Equipment & Supplies
aryanghaneka
Level 1:
  • Contributor 1 Answer
  • Posted on May 29, 2025
aryanghaneka
Contributor
Level 1:
Answers
Questions
0
Helped
763
Points
Oce 350 optimising toner distribution 5703 error code solution
Oce Guy
Level 2:
Novelist:
  • Office Equip... Expert 317 Answers
  • Posted on Apr 25, 2019
Oce Guy
Level 2:
Novelist:
Answers
317
Questions
0
Helped
195933
Points
486
Residual Toner Container Full or Missing. Waste toner. If you put a new waste toner container in and it is the same problem, it is the sensor. Try cleaning the sensor.
4 Related Answers
Everett Lin
  • 990 Answers
  • Posted on Oct 10, 2009
SOURCE: Error code E020 0181 on oce cs115 how do we remove the code
Hello sir; Try to replace yellow color developer and then running"stir" or "install". should removed the error code.
Anonymous
  • Posted on Aug 01, 2011
SOURCE: oce plotwave 300 error 8513
Dear Sunilkudal20,
the error code referes to an electronic failure in the fuser section.
  • You can try to reset the system by turn the machine off and on.
  • Check if there is no media is in the fuser section.
If this is not solving the issue, I advice you to contact you local service organization.
If you leave your country of origin, email adress and / or your telephone number, I can ask a colleque to contact you.
Kind regards,
Jack de Weirdt
Oce Technologies B.V.
The Netherlands
Anonymous
  • Posted on May 24, 2012
SOURCE: oce plotwave 300 error maintenance
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
zenseo1992
Printer Help & Support
  • 783 Answers
  • Posted on May 03, 2013
SOURCE: Oce plotwave 300
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
2answers
OCE Plotwave 345 error codes 22551(printer) and 22531(printer)
This article is about two printer error codes, 22551 and 22531. These codes are associated with the OCE Plotwave 345 printer. The error code 22551 means that the printer has lost its connection to the computer, and the error code 22531 means that there is a communication problem between the printer and the computer.
Oce Wave Plotter 300 Show Error 12507
Please verify the error code if this is a PlotWave 300. If this is a ColorWave 300, then the error is Present sensor 2 roll 2 does not open during retract. Check to see if the sensor is blocked or broken. at the input side of the lower roll.
1helpful
OCE PlotWave 300. Error 8130. Hello, OCE PlotWave 300. Error 8130. What it for an error and how to get rid of it?
Fuser Temperature Protection Circuit Failed. Turn off the printer completely. Power off in front, and turn off main power at right, rear, bottom and unplug from the wall. Open up the fuser and take off the right hand cover. This is High Voltage. If you are uncomfortable with risking your health, do not proceed further. You will see 4 connectors (black, usually but with red insulators) that plug into the right hand side of the fuser. Unplug them and check the connectors as well as test if they are seated correctly. Ensure the red insulating jackets are pushed toward the connectors. IF everything looks OK, and the printer still exhibits this error code you will have to call an authorized Oce service technician.
2answers
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
2answers
Oce Plotwave 300 8526
08526 Fuser Setpoint not reached. This will require an authorized Oce service technician to check the NTC values, fuser and wiring.
Oce plotwave 300 error 8509
Fuser NTC 1 not working properly. Replace.
Error 08130 Fuser temperature protection circuit failed. This could be the Spider PBA or it could be the connections to the fuser itself.
Best to call an authorized service rep.
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
3helpful
2answers
Oce plotwave 300 error maintenance and troubleshooting manual
9helpful
OCE Plotwave 300. Error Code 22701\printer.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
