david black Posted on May 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oce plotwave 300
Error 8528 on Oce 300
Printer Help & Support
Level 3:
  • Master 783 Answers
  • Posted on May 03, 2013
Master
Level 3:
Answers
783
Questions
0
Helped
286926
Points
1637
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
Oce Guy
Level 2:
Novelist:
  • Office Equip... Expert 317 Answers
  • Posted on Apr 25, 2018
Oce Guy
Level 2:
Novelist:
Answers
317
Questions
0
Helped
195933
Points
486
The system reports this error as a safety interlock problem for the fuser section. Either the plunger switch has failed, or there could be an issue with the connections on the fuser itself on the right hand side. Ensure that the system is completely powered off and unplugged from the wall before you go poking around inside. You are dealing with high voltages. There are 4 power connections to the fuser. Check them with a pair of pliers to see if they are seated properly and locked in place. If they come off easily or you see anything burnt on the insulators, call an authorized Oce technician. the connectors and entire fuser may have to be replaced.
Raul Pampamallco
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 04, 2014
Raul Pampamallco
Contributor
Level 1:
Answers
Questions
Helped
1737
Points
0
Need service manual oce colorwave 300 emailme to raul_rpb@hotmail.com
Create a bootable usb installation media for OCE plotwave 300
There is no online or free software to do this. You have to call an authorized service provider for this to reload the OS and firmware.
Oce Wave Plotter 300 Show Error 12507
Please verify the error code if this is a PlotWave 300. If this is a ColorWave 300, then the error is Present sensor 2 roll 2 does not open during retract. Check to see if the sensor is blocked or broken. at the input side of the lower roll.
1helpful
OCE PlotWave 300. Error 8130. Hello, OCE PlotWave 300. Error 8130. What it for an error and how to get rid of it?
Fuser Temperature Protection Circuit Failed. Turn off the printer completely. Power off in front, and turn off main power at right, rear, bottom and unplug from the wall. Open up the fuser and take off the right hand cover. This is High Voltage. If you are uncomfortable with risking your health, do not proceed further. You will see 4 connectors (black, usually but with red insulators) that plug into the right hand side of the fuser. Unplug them and check the connectors as well as test if they are seated correctly. Ensure the red insulating jackets are pushed toward the connectors. IF everything looks OK, and the printer still exhibits this error code you will have to call an authorized Oce service technician.
2answers
I have an Oce Plotwave 300 giving 22529 errors. Have replaced the spider board and usb cables. Any suggestions ?
Clean the paper tray, rollers, and clear any jams. The OCE Plotwave, being a large scale printer (used for posters and the like) is prone to jams and gumming up of the rollers. The error occurs when the paper doesn't move along properly and the sensors that read the surface and adjust the paper can't get it to adjust. Other issues can cause the same generic error. This includes incorrect PIN settings on the mainboard (some of these printers have PIN controllers that determine if it will read a certain way). It could be a read/write error in the USB control board (check to make sure all ribbons are correctly seated and all connections are making proper contact and are in the right ports). I suggest trying the OCE cleaning tool to see if that helps. Oc PlotWave 300.
2answers
Oce Plotwave 300 8526
08526 Fuser Setpoint not reached. This will require an authorized Oce service technician to check the NTC values, fuser and wiring.
Oce plotwave problem 8528
Need model number to be more accurate. But if it is Plotwave series, ensure all drawers and covers closed. Open and close the fuser cover and reset. If this doesn't fix the problem, call an authorized service technician.
Oce plotwave 300 error 8509
Fuser NTC 1 not working properly. Replace.
Error 08130 Fuser temperature protection circuit failed. This could be the Spider PBA or it could be the connections to the fuser itself.
Best to call an authorized service rep.
OCE PLOTWAVE 300 ERROR CODE 8510
JAI UN PROBLEME AU PLOTWAVE 300 MARQUE OCE
CODE ERREUR 8510
C QUOI LE PROBLEME ET C DU A QUOI ET QUESQUE JE DOIT CHANGER
MERCI
REPONDEZ PAR EMAIL
benztirage@yahoo.fr
3helpful
2answers
Oce plotwave 300 error maintenance and troubleshooting manual
Error Code 15709 is coming frequently... what should i do for this? please do the needful...
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
