Posted on Dec 10, 2009
OCE Plotwave 300. Error Code 22701\printer.
OCE Plotwave 300. Error Code 22701printer.
It says to remove print media, but does not recognize that the machine is empty. I've pressed the "OK" button, attempted to clear any paper jams, & turned off power, then turned back on...
No Improvement.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Mar 08, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
13078
Points
7
This error will be caused by a jamb inside the cutter assembly of the lower roller drawer. Remove the two black Torx screws at the left and right sides inside the lower paper drawer. Next remove the galvanized cover. You should then be able to see the edge of the paper. Grasp it firmly with a pair of needle nose pliers and pull straight up and out. Clear your errors and commence printing.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
