20 Most Recent
GIMP GNU Image Manipulation Program Questions & Answers
HOW DO I PUT PICTURE INTO ANOTHER PICTURE
In the window with the picture you want to copy, choose Select/All and then Edit/Copy. In the window where you want to put it, create or select the layer into which you want to put it, then choose Edit/Paste. You can then move, scale, and whatever.
What will be the pixel or size of tarpaulin when i used gimp?
I don't know if this will help and all and I had to search up what tarpaulin and a few things came up and I honestly dont know how big you wan't it but Im going to give it a try
1 pixel = 0.0008680556 feet
But if im wrong I would just search it up on google for converters, Im sorry im not much help even though I use gimp daily
Saving to patterns
Judea I do not know the answer to your question and I know it's a little late but hi my name is Jordan DeMaris I hope you remember me. Keep your head up and study hard little sis, your always on my mind.
Error on startup when trying to open a file
I receive the same error, but only when opening or saving a file while a removable drive is attached to the computer (typically my camera's CF card). Naturally this is annoying when processing new photos. I don't have a solution to the underlying problem, but I do have a workaround for the annoying pop-up message. It involves using Windows Registry Editor, so use at your own risk.1. Start Button -> Run2. Type "regedit" without the quotes3. Proceed through the following entries (double-click each name: HKEY_LOCAL_MACHINE -> SYSTEM -> CurrentControlSet -> Control -> Windows4. Locate "ErrorMode" and double-click5. Change the entry for "Value Data" from 0 to 26. Change the entry for "Base" from Hexadecimal to Decimal7. Click "OK"8. Press F5 to refresh the Registry Editor9. Close all windows and restart your computerAgain, this will stop the pop-up messages warning you that there's no disk, but it doesn't solve the underlying problem. If you're comfortable that there's nothing actually wrong with your computer (I am) this will at least make GIMP usable again. Thanks to jamuma on answers.microsoft.com for the original idea.
How to import a word text into gimp ?
It is impossible to import a word document file into GIMP, but it is possible to COPY the text in the document and PASTE it onto a text layer in GIMP. This, unfortunately, destroys the formatting (for instant, tabbed spaces are removed for paragraph beginnings.)Please contact me at div.ceslum@gmail.com if you have any other questions regarding text layers in GIMP.
How to put photo on gimp
To open a photo in GIMP, simply open GIMP and when the blank GIMP Workspace appears, click and drag your picture from wherever it is saved (ie: from your Pictures Folder) into the GIMP workspace.
