SOURCE: 1999 Dodge Durango NO HEAT
Bad NEW thermostat? I had the same problem on my first generation Dakota. The problem for me turned out to be the DODGE thermostat I used to replace the old Dodge part. I went and got a Stant from local auto parts store using the standard temperature spec and quit shivering the next time I drove it. I hope that helps!
SOURCE: getting rear gears out of the difential case 1999 dodge durango
SOURCE: Need to the torque specs for a 1999 Dodge Durango
Head Torque sequence
Step 1: torque to 50 Ft/Lbs
Step 2: torque to 105 Ft/Lbs
recheck final torque in sequence.
Torque intake manifold:
Step 1: 12 inch/Lbs, (hand tight)
Step 2: 72 inch/Lbs, (6) Ft/Lbs
Step 3: 12 Ft/Lbs
torque intake plenum:
Step 1: 24 inch/lb (hand tight)
Step 2: 48 inch/lb (4) Ft/Lbs
Step 3: 84 inch/lb (7) Ft/Lbs
(To torque bolts, start in center using crisscross
pattern)
SOURCE: 1999 dodge durango heater core
It's a big job. Drain the coolant down, recover the freon in the ac system and disconnect the lines and heater hoses. Lower the steering column, remove the instrument panel assembly, remove the heater housing. Split the case halves on the housing and there you are. Usually around 500 to 700 dollars at a dealership.
SOURCE: Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
