Vehicle Parts & Accessories Logo
Posted on Jul 05, 2011
Have a python 1500HF box under my column.has four dip switches and two jumpers visible.is there and override position to see if the system is not allowing me to start the engine. found a remote toggle switch but it appears to do nothing in either position.
5 Related Answers
Anonymous
  • 63 Answers
  • Posted on Jan 10, 2011
SOURCE: We just realized that the previous owners of our
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Anonymous
  • Posted on Nov 14, 2008
SOURCE: Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Anonymous
  • 244 Answers
  • Posted on Jan 16, 2009
SOURCE: need to match DIP switchs on a universal garage door remote
I find Clicker products confusing. Might want to buy whole new replacement readio control set. how old is operator?
Anonymous
  • 75 Answers
  • Posted on Apr 26, 2009
SOURCE: Hampton Bay Windward II dip switches
The CODE SWITCH RECEIVER should be located in the CANOPY (the bracket hanger). !!WARNING!! YOU ARE ENTERING A HIGH VOLTAGE ELECTRICAL ZONE!!
It will be tucked in among the electrical wiring and inside the hanger bracket.
Simply pull it out and you will see the CODE SWITCHES. There are 16 CODE combinations that can be used. Both the REMOTE and the RECEIVER MUST be set with the SAME CODE.
Good luck. :)
Anonymous
  • Posted on Jul 16, 2009
SOURCE: No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Top Python Vehicle Parts & Accessories Experts
john h
Arnie Burke
Arnie Burke
Jonathan Buck
Jonathan Buck
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
