SOURCE: error code 6500
This is caused by the information in your registry. Please refer to the following link and download the Advanced Windows Care ... you will not be disappointed ... Scan with AWC and try your printer again. The message displayed is an error, I am supposing.
http://www.iobit.com/advancedwindowscareper.html
Terry
SOURCE: error code 6500 flashing
The 6500 error code is a logic board error code. The PCI Bus error is detected by the ASCI. Sounds like it needs new logic board. but i suggest you to first of all you can try to reset your printer -
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on. If this works you're done, if not try the next step.
1. After confirming that the printer is powered on, open the paper output tray.
2. Open the top cover and wait until the print head moves to the center.
3. Open the inner cover and check that ink tanks are properly seated.
4. Properly seated
5. Press down on each ink tank until a click is heard.
6. Close the inner cover and top cover
if reset method not works for you then you go for the new logic board replacement .............
Good Luck!!
Thanks
SOURCE: my canon mp830 had an error code 6500. I turned it
The 6500 error code is a logic board error code. Sounds like it needs new logic board assembly.
Testimonial: "Thank you cene765. I think my next printer will be an HP."
SOURCE: Error code 6500
That's a strange error for that machine, a network error? I would try removing the printhead and see if the error changes to printhead not installed, could just be a defective printhead which can cause strange errors.
