this might be caused by your antivrus being outdated you might upgrade or update or uninstall it then restart your computer then do a reinstall hope it helps
LP5 code error normally means that the package is corrupt. This can happen as a result of a bad download or malware on your PC. or This program has been damaged, possibly by a bad sector on the hard drive or a virus.
hi, There isn't much accurate information about this LP5 error on the web. Here are some facts.
Programs as "packed" to reduce space, stop hacking and help prevent pirating of the software.
Good packing software is hard to write. So packing is often done using external software protection applications. One of these packages is "Armadillo" from Silicon Realms. Now called Software passport.
Protected programs are "unpacked" each time you run them. Normally this is not problem and you never notice it happening. When things go wrong during this process you get the LP5 message like, "Error while unpacking program, code LP5. Please report to author".
Only Silicon Realms really know what LP5 stands for. But it is enough to know that unpacking failed.
Sometimes, very rarely, you get a corrupted download that prevents correct unpacking of the software. The solution here is to get a new download package.
Also, very rarely, there is 3rd party software running on the same machine that interferes with the correct operation of the packed application. We saw this when CA's Antispyware product had a bug that messed things up. The solution here is to identify the application causing the problem and uninstall it or get the bug fixed. Which is what we did for our software.
error with code LP5 is indicate the software are being corrupted.. please reinstall ur program but please update your security for latest updated first, if u get the software with download, do get a new download package. his solve ur problem ? :) i wish u luck
This can be caused by a computer virus that prevents a program from unpacking... you may need to have a better antivirus like kaspersky Internet Security 2009, norton antivirus 2009....
Remember not all antivirus can detect virus... some virus can destroy your pc... especially the hard disk...
this two antivirus is what i have tested to be good in protecting the computer from viruses...
Greetings,
Here is the best solution to the problem as I faced one of similar sort.To help resolve the code 5 error please try the following.
1. Reboot 2. Navigate to \Program Files and delete the \Registry Mechanic folder 3. Download Registry Mechanic from http://www.pctools.com/registry-mechanic 4. Install Registry Mechanic that was downloaded in step #3 above.
I have the same problem "Error while unpacking program, code LP5. Please report to author" Here is the Solution: 1. The number one solution is to disable or turn off your current anti virus for a while or every time you use that program showing "Error while unpacking program, code LP5. Please
report to author." ,
then restart your computer,
open the program again which
previously having error "Error while unpacking program, code LP5. Please
report to author."
Then after using the program, you can enable or turn on the anti virus.
Note: If you will enable the anti virus, the error message to that program will show again; in that case, if you want to use that program again, disable the anti virus again for a while then restart your PC
