Computers & Internet Logo
Posted on Aug 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error while programming code lp5 report to the authour
Code lp5
Steve Nordquist
Level 3:
  • Master 982 Answers
  • Posted on Aug 24, 2009
Steve Nordquist
Master
Level 3:
Answers
982
Questions
Helped
217519
Points
2276
I doubt this is the author's website.  Honestly, read the requester's title or at least get a clue as to what programmer or IDE you were working with.
1helpful
2answers
Babyran error while unpacking program code lp5
i don't have any anti-virus !!! what can i do ??
2helpful
Error while unpacking program, code LP5,please report to author.
It seems to be caused by interference from other applications running on the computer such as AV products. It may also be possible that this Ceedo product you are using is the cause of the problems. Any extra info about how you are trying to run KeyboardTest could help us in troubleshooting the problem.
FACTS ABOUT CODE LP5:
  • Programs as "packed" to reduce space, stop hacking and help prevent pirating of the software.
  • Good packing software is hard to write. So packing is often done using external software protection applications. One of these packages is "Armadillo" from Silicon Realms. Now called Software passport.
  • Protected programs are "unpacked" each time you run them. Normally this is not problem and you never notice it happening. When things go wrong during this process you get the LP5 message like, "Error while unpacking program, code LP5. Please report to author".
  • Only Silicon Realms really know what LP5 stands for. But it is enough to know that unpacking failed.
  • Sometimes, very rarely, you get a corrupted download that prevents correct unpacking of the software. The solution here is to get a new download package.
  • Also, very rarely, there is 3rd party software running on the same machine that interferes with the correct operation of the packed application. We saw this when CA's Antispyware had a bug that messed things up. The solution here is to identify the application causing the problem and uninstall it or get the bug fixed. Which is what we did for our software.
Please vote if this post helps you in anyway.
Regards
George
5helpful
Error while unpacking program, code LP5. Please report to author. how to fix it
LP5 code error normally means that the package is corrupt. This can happen as a result of a bad download or malware on your PC.
or
This program has been damaged, possibly by a bad sector on the hard drive or a virus.
Hope it helps.
1helpful
Error while unpacking program, code LP5. Please report to author. my email id is sameer_msb77@rediffmail.com pls revert back as soon as possible thank u
Please search your registry for this exact string. Copy and paste it to your search parameter.
C:\WINDOWS\system32\svdhost.exe
If you have this, it is a Trojan Virus and you need to act quickly to remove it.
It's an oldie, so most good antivirus programs and anti-rootkits should save you.
Other forms of LP5 may be genuine and related to Zip file problems from genuine programs, and are simply corrupted, but somehow I doubt this is the case.
6helpful
Error LP5
hi,
There isn't much accurate information about this LP5 error on the web. Here are some facts.
  • Also, very rarely, there is 3rd party software running on the same machine that interferes with the correct operation of the packed application. We saw this when CA's Antispyware product had a bug that messed things up. The solution here is to identify the application causing the problem and uninstall it or get the bug fixed. Which is what we did for our software.
1helpful
Lp5 error
hi,
2helpful
2answers
This can be caused by many reasons,Please post computer an installed software details,This is usually caused by an antivirus program or a virus but can be caused by any downloaded or packaged software
2helpful
2answers
This can be caused by a computer virus that prevents a program from unpacking... you may need to have a better antivirus like kaspersky Internet Security 2009, norton antivirus 2009....
Remember not all antivirus can detect virus... some virus can destroy your pc... especially the hard disk...
this two antivirus is what i have tested to be good in protecting the computer from viruses...
hope it helped you... tnx...
63helpful
8answers
I have the same problem "Error while unpacking program, code LP5. Please report to author"
Here is the Solution:
1. The number one solution is to disable or turn off your current anti virus for a while or every time you use that program showing "Error while unpacking program, code LP5. Please report to author." ,
  • then restart your computer,
  • open the program again which previously having error "Error while unpacking program, code LP5. Please report to author."
  • Then after using the program, you can enable or turn on the anti virus.
  • Note: If you will enable the anti virus, the error message to that program will show again; in that case, if you want to use that program again, disable the anti virus again for a while then restart your PC
  • I hope this help you very much. Thank you!
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
