SOURCE: i am locked out of my phone
If you don't know your password, go to your local retailer that distributes that phone (for example, t-mobile) and they will unlock it for free
SOURCE: I just installed a Smartcode Deadbolt and I follow
On the back of the unit slide the cover off and push the 2nd switch (on the contorl panel of four switches) down.
To program the code, push the black button once and enter a 4 to 8 digit code, then press the middle lock button. To set a secondary code, press the black button twice, enter 4 to 8 digit code and press the lock button.
This should all be self explanitory in the instruction manual.
I have one of these on my front door and its fantastic. I carry a key but have not used it in months. Bravo Kwikset, Bravo!
SOURCE: I'm using a kwikset smartcode
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
SOURCE: Weiser combination lock beeps
You should check if the keyboard ribbon cable is properly connected and not pinched or cut ... Also it is possible that water has entered into the keyboard. In case you should remove and dry with a hair dryer.
SOURCE: Hotpoint Aquarius TDC32 condenser dryer swittches
if hotpoint tdc 30 stats blow does tumbledrier fail to switch on?
