Dell Inspiron 1545 Notebook Logo
A
Anonymous Posted on Sep 05, 2014
Erratic pointer pointer works fine when first used then starts moving everywhere on its own,difficult to control it,I have updated,downloaded new software,no change.any replies please in simple terms,I am no expert.thanks in advance
KEVIN MCNAMARA
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Sep 06, 2014
KEVIN MCNAMARA
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
196
Points
5
The erratic pointer in the dell inspiron 1545, is a common fault. The usual cure, is to unistall the driver. Reboot install the driver again. Also check your graphics settings. If that doesnt cure the problem. You will need to overwrite/erase your hard drive do a fresh install.
3 Related Answers
Anonymous
  • 181 Answers
  • Posted on Nov 06, 2007
SOURCE: Dell laptop pointer problem
This is a very common problem for most Dells this age.
You can try this repair if you feel comfortable.
Remove the keyboard by removing the power button bar (just gently pry up from the right side working left)
re-insert the mouse cable which is coming from the pad/palm rest. Re-assemble.
Check if all the screws on bottom of the unit are tight, especially around the palm rest area.
Good luck
Anonymous
  • Posted on Mar 07, 2009
SOURCE: Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Anonymous
  • 1288 Answers
  • Posted on Jan 02, 2011
SOURCE: touchpad is not working correctly. It is touchy.
Sounds like wear on the contacts, if you can try applying a little pressure to the centre of the pad, and it works better, this is the issue. As a first resort, you could try and download the touchpad driver and re-install it, howver, this is a common fault with the touchpad. You may need to have it replaced or possibly cleaned
Testimonial: "Thank you I will try! You rock!"
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
