GE WCVH6260FWW Logo
A
Anonymous Posted on May 28, 2014
How do I pull up error codes
Can I try to pull up error codes to see what is going on with the rinse cycle stopping?
Pete O
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 17 Answers
  • Posted on Jun 01, 2014
Pete O
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
17
Questions
0
Helped
5987
Points
20
Follow these steps to enter the service mode on a GE front load washer. 1. Close the door.
2. Clear current cycles by pressing the power button. Make sure the screen is blank before attempting to enter the service mode.
3. Disconnect power to washer for at least 30 seconds.
4. Reconnect the power and within 30 seconds of reconnecting power complete the next step.
5. Press signal -delay start -signal - delay start.
If you successfully enter the washer into the service mode, t01 will be displayed and the door will lock.
Here's a link to the codes: http://www.appliance-repair-it.com/GE_front_load_washer.html
Good luck with your troubleshooting!
1 Related Answer
cost1954
  • 3 Answers
  • Posted on Oct 14, 2007
SOURCE: ZWashing machine stops at spin cycle
I just had a similar problem with my GE washer, mod # WPRB9110D1WW.  I had 2 different GE service men come out - the 1st  one was no help, said to unplug the washer for 5 minutes to reset the electronic controls - worked 1 time doing this.  The 2nd service man came out, told him it would stick in the rinse cycle and not spin, also had short fills of water.  He immediately popped off the front of the washer (insert a putty knife in 2 locations at the top), and showed me there was a plugged up pressure switch tube (clear plastic) located on the lower left side of the tub; he pulled the tube off the connector to the switch, cleaned it out with a small screw driver, reattached it, and it has worked fine ever since then.  It took all of 5 minutes to fix it.  He suggested washing some rags with bleach every month or so, said the bleach kills the bacteria build up that causes the stopped up tube.  This service man told me, a lot off people replace the electronic control panel needlessly for this problem, and waste their money.  I don't know that this is you fix for your proble, but it's something easy to do.  Hope this helps!
Top GE Washing Machines Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
