My washer keeps stoping just before it is able to completely drain. The "dr" shows up and then to keep it going i have to press the start button again and then it adds more time on the cycle and keeps draining. This usally happens once or twice per load. I always empty the lint traps and i don't over fill it. What am i missing?
Your pump is either bound up with something in the chamber, or there is something in your discharge hose blocking the water from escaping.
Look on the back of the washer, and unscrew the circular port in the bottom right corner. (Keep an 8x13 baking pan underneath, water will escape once you open the chamber). Check if there is anything in the chamber that is binding the impeller. If not, remove the metal back and check that all three of the hose connections to your pump are open and have no debris/ change, etc. If there is nothing binding your pump in any of those locations, your pump motor may be failing. I would suggest calling someone out to assist you.
It was the kink in my hose.
i just moved my washer to a different location in my apartment, and suddenly started to get the "dr" message, and as others have described, it would get to 13 mins and then stop. i came here to find out what "dr" meant, then upon reexamining the back, i found that there was a big old kink in the base of the hose where it met the machine. i finally figured out what the hooks on the upper back were for. i unkinked the hose, inserted it into one of the hooks to keep it straight, and suddenly the drain which had been a trickle turned into a blast. problem solved. (for me that is.) my washer is now happily on its way to the end of the cycle.
brian
I am having the same problem with my washer it is displaying "DR" the washer is fairly new! This has been going on for a few days- it displays "DR" and beeps!
HELP
I have the exact same problem. It makes a horrible crunching noise and displays "dr" and won't drain
The machine goes through a normal wash cycle
from 53 minutes to 28 minutes. At 28 minutes the machine starts to drain for
about 5-6 minutes, but the timer stays at 28 minutes. At which time a
"dr" code appears, the machine beeps and the machine stops.
If the machine is reset, it starts at 22 minutes
and goes through the 2nd wash cycle. The machine works fine from 22 minutes to
13 minutes, then it repeats the above process.
When I manually set the machine for the Rinse
cycle, it starts at 13 minutes and drains for 3 minutes, then stop at 10
minutes.
If I set the machine for Spin, it starts at 13
minutes and the timer stops at 10 minutes, but the water continues tickling out
for another 5-6 minutes before the "dr" code appears and the machine
stops.
As a test, I manually set the machine on Spin about 20 times. Once ALL
the water is drained the machine will spin, and spin and spin; Until a new load
is started..
