Trying to up date java to java plug-in 10.45.2.18.JRE version 1.7.0._45-b18 java hot spot (TM)cliant VM can you help? do not know how to install
SOURCE: Unable to View Java Applet
"load: class JFI.class not found."
Based on the console output, it means that it cannot find the java applet class. In other words, the applet is missing on the server side. There is nothing that you can do about it, unless you know the person who created the applet. Good luck :)
SOURCE: Opening Wordbiz
Issue
Wordbiz 1.8 does not launch when you run it under vista.
Solution
Just run the program administrator for this:
1. Right click on the icon WordBiz ISC RO
2. Properties
3. Compatibility tab
4. In the Priviledge level section check the box Run this program as administrator.
5. Click OK and restart your application.
http://en.kioskea.net/faq/sujet-3774-wordbiz-isc-ro-does-not-run-on-vista
& we'll sit by the qat and have some za!
SOURCE: java (TM) Plug-in fatal error
Java (TM) Plug-in Fatal Error
Several java Virtual Machines runing in the same process caused an error
SOURCE: trying to install java 6 it says i already have
DOWNLOAD UNINSTALLER APPLICATION FROM INTERNET. IT WILL UNINSTALL THOSE THINGS UNABLE TO UNINSTALL
