These little warning boxes keep popping up saying java (TM) Plug-in fatal error. And that several java virtual machines running in the same process caused an error. please could you help me solve this problem or if you know exactly what to do. as soon as possible would be great as i use the errored site on a daily basis.
many thanks
Java (TM) Plug-in Fatal Error
Several java Virtual Machines runing in the same process caused an error
To view this page curectly intall java virtual machine pc destop of window xp operative system.
Try to uninstal all the versions of java from control panel --> Programs & Features --> uninstall all Java related softwares and restart the system and then install it
I don't want Java TM Plug-in Fatal Error
I have the same problem as you. I've tried uninstall, re-install, updates and everything.
The problem still persist as well.
Any better suggestions?
Did you try to uninstall Java thru Add and Remove Programs from you're control panel? It's possible that you have more then one version of Java loaded on you're system. If so uninstall all versions. Then reboot.
i have the same problem could some plz help me here ty
