ASUS Eee PC 1011PX-EU17-BK 10.1" Netbook PC - Black Logo
A
Anonymous Posted on Sep 25, 2013
Error code FFFF
I HAVE AN PROBLEM WHEN I START MY LAPTOP THAT IS UNKOWN BIOS ERROR CODE IS FFFF
FFFF error code on convection preheating
F is for fan. Why is your fan not doing its job I ask?
2answers
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation
As soon as you power on your PC, start pressing the F2 key. This should bring up the BIOS (Basic Input Output Systems) screen. Make sure your Hard Drive is listed in the Boot order. Usually a CD drive is listed first, then the Hard Drive as a second boot device. If you do not see the Hard Drive listed, then it probably is bad and needs replacing. If it is listed correctly in the boot order, your Operating System has crashed, and you will need the recovery disks or the instalation disk for your Operating System (XP, Win7,etc.)
1helpful
Crashed error 03-FFFF-OOOO
if that error occurs while attempting the recovery, typically it indicates a read write error on the hard drive. replace the hard drive and see if the recovery finishes.
(although i have only seen this problem with failing hard drives)
2helpful
Bios error of type ffff plis assist to trouble shoot.
download the EXACT bios for that motherboard and flash the bios
2helpful
2answers
Code error ffff:0024
While I am trying to scan the images, I am getting the error Code[ffff:0024] & I am unable to scan anything from Epson 1500 model. While I switch on the scanner, it sounds lot from the scanner for continuous 2 minutes. I couldn't get scanned anything ... please
give me the solution.
4helpful
2answers
Benq flatbed sacanner is not working
As far i know this problem 0024 is concern about ur power adaptor is not passing the right voltage to scanner [ffff:0024] is power adaptor error . change the power adaptor to its genuine power adaptor , ur problem is solved
12helpful
8answers
Getting error code Code[ffff:0024]while scanning
while i am trying to scan the images .. i am getting the error code like Code[ffff:0024] while warming up the scanner, besides a sound from the scanner making it power off (light inside the scanner goes off ) so that i could not get scanned anything ... what will be the reason ? please suggest me the trouble shoot kaarthik
Top ASUS Audio Players & Recorders Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Wale Sarumi...
Wale Sarumi...
Are you an ASUS Audio Player and Recorder Expert? Answer questions, earn points and help others
