SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
