A
Anonymous Posted on Aug 28, 2014
Error code sc545
Ricoh mp 4500 error code sc545
Grand Canyon Tech
Level 3:
  • Master 3,869 Answers
  • Posted on Aug 28, 2014
Grand Canyon Tech
Master
Level 3:
Answers
3869
Questions
Helped
1344539
Points
12723
The Error Code SC542 or Sc546 could be a caused by a few reasons. There is a temperature problem with the fuser unit, the roller thermistor is bad, or the BCU Board is bad.
1 metode to reset Ricoh Error code sc542:
To clear the code:
Hit the yellow "Clear Modes" key
Press 107 on the number pad
Press and hold the "Clear Stop" for 10 seconds until you get a new screen ...
Press the "Copy SP" Button on the display
Open the front door
Turn front left power switch off and on
Shut the door
The error code is now cleared.
To Enter and Exit the SP Mode
1. Press yellow "Clear Modes" key .
2. On the operation panel keypad, press 107 number
3. Hold down red "Clear" key more than 10 seconds.
The Copy SP is displayed.
4. Press "Copy SP" and go to the code SP5810, press "Execute"
5. To exit the SP mode, just press Exit in the upper right corner of the SP mode
screen. Power switch off and on and the error code is now cleared.
Hope this his helps, thanks for using fixya.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
5 Related Answers
Everett Lin
  • 990 Answers
  • Posted on Apr 09, 2009
SOURCE: this is the code on the mach sc 545
Hello sir; The code sc545 means fuser unit temperature too low it can be reset;
press "clearmode" "107" and thenpress and hold "clear/stop" key untill display "copy sp" show up, then turn power off and back on.
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 26, 2009
SOURCE: Ricoh copier MP 6000 error code
THIS IS USUALLY FOR THE FUSER SECTION IT MAY BE THAT SOME TONER HAS BUILT UP ON THE THERMISTOR AND IT AINT READUNG THE TEMP PROPERLY AT WARM UP OR ON A RUN IT HAS TO OVERHEAT TO GET RIGHT READING TAKE THE FUSER OUT CHECK THE THERMISTORS.. YOU COULD ALSO GO INTO THE SERVICE MODE VIA CLEAR ALL THEN 107 AND HOLD DOWN THE RED STOP BUTTON TILL THE SCREEN CHANGES IF YOU LOOK FOR COPIER SP IN THE FEED SECTION THE FUSER SETTINGS ARE THERE YOU CAN OPEN FUSING TEMP AND CHECK THE TEMPS AT THE TIME TO SEE IF THEY ARE RIGHT.. IF IT SEEMS RIGHT IT MIGHT HAVE BEEN A READ ERROR AND BY GOING INTO MODE AND LOOKING FOR 5- 810 YOU CAN RESET THE SC TURN OFF AND THEN BACK ON IT SHOULD CLEAR... GOOOD LUCK A
M2Tech1
Andy Bell
  • 313 Answers
SOURCE: error codes SC545 for Ricoh Aficio 1045
yes you may it refers to a temp error int eh fuser... you may have a faulty thermistor or thermo fuse.. if you go into teh service mode by presssing teh yellow clear butto and then press 107 and then hold down the stop button the sreen will change turn the machine off and turn on again see if the errpr goes if it does it could have been just a temp error if it warms up then comes back on again you will have to look at the fuser.. you can check the fuser by touching the casing and see if it is warm after you have turned the machine back on..if it is warm the error could just be due to a build up of toner on the thermistor.. if you know about machines you can take the fuser out by opening the front of the machine up look to top right where fuser is there is a screw under the blue dial on the fuser take that out the fuser slides out put it on some paper and on the right hand side is the thermistors held inby a small screw if you take them out you may see some build up of toner on the resistor carefully clean this off.. put back together and turn on .. hopefully it will run ok.. good luck A
Anonymous
  • 29 Answers
  • Posted on Aug 18, 2009
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
joel_baleta
Joel Baleta
  • 155 Answers
  • Posted on Jan 26, 2010
SOURCE: ricoh 1045 showing code SC545. First was SC 546
SC545 and SC 546 are fuser temperatyre error. pls. check thetmistor/ thermostats, connectors if thernistor are deffective replace thermistors. after replacement or checking of this parts do the SC reset. 107 # turn off copier then on after 5 sec.
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
