May depend how it was programmed. My Python 476P was setup with Lock and Unlock pressed to get it to remote start. Then, get in the vehicle, put the key in the "on" position and press lock / unlock to get it to end the remote start cycle. Then Drive off ...
I got a second remote, followed some directions via YouTube to program. Key in the on position, then hit the valet button once, then press and hold. One chirp, hit lock on remote. Let go of valet button . Press, then press and hold, two chirps. Hit unlock. Continue for 3 (aux) and 4 (panic). End result was Lock would also unlock. Unlock did nothing. And Aux started the remote start sequence.
Having bought a vehicle used, then no manual made this a bit difficult. I will continue to test alternate programming to try to match the original remote so accidentally firing up the rig doesn't happen. My suspicion is I have to maybe do Lock, Aux, Lock/Unlock, panic instead. Good luck.
SOURCE: I bought a 2002 jeep
the lock button should arm the alarm, the unlock should dis arm the alarm. aux on this vehicle should not do anything and the red button should set off the alarm for panic button. You cang et a copy of the owners manual at Directed Electronics website
SOURCE: one of my remotes will no longer operate my Python
This is a common problem on these and the equivalent viper models. We sent all our units back to viper and they have now re-released the units. We had installed these units into customers vehicles and about 50% had the same issue your having. Even after they were reprogrammed, many returned with the problem again. My advice is to contact python and have the unit replaced.
SOURCE: python car starter 951
unlock car via remote Push and hold F button for about 8 seconds until it says setup remote on the screen Use the aux and remote start buttons to scroll to CLOCK and then use the F button to access menu.
SOURCE: Python 1600 XP Remote Starter my
You have the 24 hr timer on and you just have to press the lock and remote start buttons at the same time.
