20 Most Recent Atari 2600 Console Questions & Answers
2answers
Atari 2600, only get black and white, no color
Well i think that the rf switch might be causing the problem snowy tv scrren no colour or fuzzy tv screen then its the rf switch thats causing this type of a problem then. If using a digital tv you need to plug it into a VCR or a DVD player for it to work then.
4/28/2023 11:14:53 PM • Atari 2600... • Answered on Apr 28, 2023
I insert the game it comes on the screen but i
I am guessing that your Atari 2600 consoles control ports could be broken or loose and need to be replaced or resoldered again.
3/16/2021 1:49:15 AM • Atari 2600... • Answered on Mar 16, 2021
My atari 2600 heavy sixer isnt working. im afraid its something with the circuit board
There could be a certain part of your Atari's 2600 consoles mainbaord inside of your console and a certain part went bad and needs to be replaced.
3/15/2021 2:46:32 AM • Atari 2600... • Answered on Mar 15, 2021
Sound cuts in and out on atari 2600 heavy sixer
The part inside of your Atari 2600 console that controls the sound and also has the sound playing through the speakers on your TV is worn out and needs to be replaced.
3/14/2021 8:51:22 AM • Atari 2600... • Answered on Mar 14, 2021
2answers
Why does my Atari 2600 console start to stall or
Alien alerts.
8/4/2018 8:06:31 AM • Atari 2600... • Answered on Aug 04, 2018
manual
2600 Console Manual
Atari 2600 ConsoleUploaded on Dec 07, 2015
Where do the white and yellow RCA cables go on my smart TV
The should go to the female colour coded RCA jacks on the TV if they are not present then your TV doesn't natively support them and you may need to buy a SCART to RCA adapter.
3/11/2015 12:30:17 PM • Atari 2600... • Answered on Mar 11, 2015
Atari 2600 manual
Here is a good site to find stuff about ataris AtariAge Have You Played Atari Today
2/21/2015 1:46:07 PM • Atari 2600... • Answered on Feb 21, 2015
Flicker screen
It might be an RF cable problem. Try an RCA to F type connector. You might be able to pick one up at radioshack.
2/21/2015 1:43:28 PM • Atari 2600... • Answered on Feb 21, 2015
The game starts to play then becomes staticky
It could be an RF cable problem. Try an RCA to F type connector. You might be able to get one at radioshack.
2/21/2015 1:41:11 PM • Atari 2600... • Answered on Feb 21, 2015
Why does my Atari woody 2600 only play in black
There is a switch by the car slot that will switch it back to color.
2/10/2015 1:56:41 AM • Atari 2600... • Answered on Feb 10, 2015
Atari 2600 video chord
This is the best way.
2/10/2015 1:55:13 AM • Atari 2600... • Answered on Feb 10, 2015
Rolling, Shaky picture
My best guess would be the video adapter switch you have to use to hook up the game console to the TV. If I remember correctly you have to slide a switch to either TV or game depending on whether you are watching TV or playing a game. Over time switches like that need the internal contacts cleaned. You can probably get a can of contact cleaning spray at Radio Shack. Just follow the directions on the can of contact clearer and you will probably fix your problem.
2/15/2014 2:29:38 AM • Atari 2600... • Answered on Feb 15, 2014
I have a atari 65
here is a site with the pin out http://atariage.com/forums/topic/184792-800xl-power-supply-connector/ , so if you want to try and use a ATX power supply you could mod it for the Xl
1/27/2014 8:57:20 PM • Atari 2600... • Answered on Jan 27, 2014
When playing the system it will start out with a
dirty contact surfaces on the end of video cable or the switch box terminal are suspect. you can use very fine sandpaper rolled to clean inside the plug on end of cable. a wiggle test should find the poor contact. other cause, overheating video in game unit. clean vents
1/25/2014 7:16:58 AM • Atari 2600... • Answered on Jan 25, 2014
Black screen horizontal white line moving from top to bottom of screen
Hi Mandy Think you have a problem with the cabel or if you could adjust the channel for the correct signal. Maybe the tv-chip on the consol are broken, and you live to far from me for me to help :) you have any friend who could take a look ? Best regards Joakim
1/24/2014 11:29:06 PM • Atari 2600... • Answered on Jan 24, 2014
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
11/3/2013 5:42:31 PM • Atari 2600... • Answered on Nov 03, 2013
Atari 2600 Console Logo
Popular Tags
195 questions posted
Top Atari Video Game Consoles & Games Experts
Aron
woodzowl307
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Atari Video Game Consoles & Games
Most Popular Question
insert game comes screen but
  • Video Game Consoles & Games
