20 Most Recent Eclipse CD2000 CD Player Questions & Answers
4answers
ECLIPSE CD5425 LOCK CODE
throw it in the trash no good cant reverse
6/3/2016 10:54:06 PM • Eclipse CD2000... • Answered on Jun 03, 2016
0answers
Which cord is the antenna on eclipse cd receiver model 8443
It will be the black cord with a female connection half inch hole, or there will be a small half ince hole in the back of unit where the antenna wire will plug inn
6/16/2014 8:40:01 AM • Eclipse CD2000... • Answered on Jun 16, 2014
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security". ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
12/24/2013 7:08:02 AM • Eclipse CD2000... • Answered on Dec 24, 2013
Need Wiring Diagrams for Eclipse CD2000 CD Player
The wiring diagrams are in this installation manual.
12/6/2012 4:56:27 AM • Eclipse CD2000... • Answered on Dec 06, 2012
0answers
0answers
Set clock on radio
Try the following website for the instruction on how to set the clock radio.
http://www.eclipse-web.com/us/manuals/manuals.html
8/17/2010 4:55:11 PM • Eclipse CD2000... • Answered on Aug 17, 2010
How do you set the clock?
The following website will help you out.
8/17/2010 4:54:40 PM • Eclipse CD2000... • Answered on Aug 17, 2010
I installed my cd player but it only plays the
by "play" im assuming u mean no audio... check the wires, in the back there should be 2 blue wires, one has a white stripe... splice them together or reverse them... it sounds like you have it hooked up to the power antenna wire (should be solid blue wire) is sending power for the amp to turn on only when the fm is playing... you want the amp turn on wire (blue with a white stripe) to be hooked to that factory wires so when the radio is on your factory amp is triggered... if that doesn't work let me know there are other thing you can try...
5/2/2010 3:36:12 AM • Eclipse CD2000... • Answered on May 02, 2010
When the radio is on the sound comes out of all
are you running separate amps for the woofer and speakers??? sounds like you have the woofer amp being turned on be the amp remote wire (blue/white) and the speaker amp turned on with the power antenna remote wire (blue). if this is the case you need to use the blue/white to turn both amps on.
4/30/2010 4:47:19 PM • Eclipse CD2000... • Answered on Apr 30, 2010
IS there a left and right audio input in the rear
No, the RCA jacks on the back of a CD2000 are line-out, not inputs.
2/4/2010 1:32:29 PM • Eclipse CD2000... • Answered on Feb 04, 2010
I am trying to connect an I-Pod through RCA inputs
Turning the Ipod's volume up may help. I had the same issue with a Sony deck in my truck and it was as simple as that! :^ )
7/3/2009 1:49:19 PM • Eclipse CD2000... • Answered on Jul 03, 2009
0answers
2answers
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
4/22/2009 9:54:19 PM • Eclipse CD2000... • Answered on Apr 22, 2009
Eclipse cd2000 car stereo
does it have a reset button or switch.. usually found on the underside of the face plate
11/15/2008 2:02:12 PM • Eclipse CD2000... • Answered on Nov 15, 2008
Eclipse deck CD5425
push func on top right then use secod nob (track select) find clock adjust and set
11/7/2008 3:00:55 AM • Eclipse CD2000... • Answered on Nov 07, 2008
CD Ejects
A couple of suggestions. Check ALL the fuses, most units have 2 or more. Search the front panel carefully, many units have a tiny 'reset' switch, which is activated by pushing a pencil point into it's hole. They are usually marked, but with tiny letters.
7/9/2008 12:39:20 PM • Eclipse CD2000... • Answered on Jul 09, 2008
Eclipse CD2000 CD Player Logo
Popular Tags
30 questions posted
Top Eclipse Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Eclipse Car Audio & Video
Most Popular Question
need wiring diagrams eclipse cd2000 cd
  • Car Audio & Video
