20 Most Recent Ematic 7" Touch Screen Tablet Questions & Answers
My ematic 7 inch quad-core tablet wont turn on or charge
Either your charger is fubar or your batteries can no longer take a charge.
10/12/2016 1:44:24 AM • Ematic 7" Touch... • Answered on Oct 12, 2016
New tablet turrns on then fades to black
That sounds like a power saving setting. Check your settings. (look for the gear looking icon, should be in there)
9/5/2016 1:35:31 AM • Ematic 7" Touch... • Answered on Sep 05, 2016
Hey, I love my tablet but I dropped it last night and cracked the screen. How much will it cost for you to fix my screen? I haven't had it but about 2 months.
Ain't gonna be cheap, that is for sure. Get a quote and see if repair is cost effective. Might not be!
6/2/2016 2:17:06 AM • Ematic 7" Touch... • Answered on Jun 02, 2016
Can you get bluetooth or playstore on theese
if you are referring to 7 Multi Touch Tablet . Look at the specs page https://ematic.us/shop/egm002.html#Tech-Specs It does not support Bluetooth and cannot be added. It is hardware component and cannot be added from playstore.
4/19/2016 11:49:30 PM • Ematic 7" Touch... • Answered on Apr 19, 2016
Tablet will not stay charged. You can actually sit and watch the power be drained.Please help!
the power supply may be going bad, may need to be checked
4/7/2016 11:57:20 PM • Ematic 7" Touch... • Answered on Apr 07, 2016
0answers
Why is it stuck in reboot mode?
You've either got a faulty update or some system errors. Do a factory restore as soon as you take your stuff off it.
3/6/2016 6:33:33 PM • Ematic 7" Touch... • Answered on Mar 06, 2016
Why is it stuck on the reboot screen?
reset it somewhere to push a few buttons together by reboot or start this will maybe the tablet goes booting in a bios factory mode with Chinese symbols like a Polaroid smartphone.
3/6/2016 5:32:44 PM • Ematic 7" Touch... • Answered on Mar 06, 2016
2answers
Forgot my unlock pattern how can I reset it
You could try the reset button on the back. It's not really a visible button but a hole into which you can poke a paper clip. Turn on the device until it gets to the pattern lock screen and then use a paperclip to gently press the reset button in the hole in the back until you feel it click. It should reboot but it will probably STILL require the pattern. (Most do, only a few don't) If it does indeed still require the pattern you'll have to go with the factory reset option which will wipe all your data and restore it to the same condition it was when it first arrived. This is drastic but there's just no way around a forgotten PIN or Pattern other than this. They do it that way to protect lost devices from having all your password protected sites like GMail etc. being accessed and taken over by somebody else. The way to do a factory reset on an Android tablet is turn it off and then turn it back on by holding down both the power button and the volume(-) button at the same time and keep holding them for as long as 30 seconds until you see some green writing on the screen. This green writing is list of options among which you will see a Wipe Data/Factory Restore option (or similarly worded) . Use the volume(+) button to scroll to the Wipe Data Factory Restore option. Once it's selected, push the power button once to engage. On most Android devices, you will then get another screen with writing that is a list of no no no no and one line with a proceed with the reset option. Scroll to it using the volume (+) button and select it using one push of the power button. The unit should then either turn off or go to another screen where you can turn it off using the power button. When it's off, give it several seconds and then push and hold the power button until it boots up. You will have to go through the set up routine again and update apps you want updated and add back the apps you had installed from the Google Store. You will have to again add your password for the wi-fi you are using before you may do any updates because the password will have been wiped, too. Good Luck and I'd recommend using a PIN instead of a pattern and WRITE IT DOWN so it can't be forgotten.
1/1/2016 4:55:03 AM • Ematic 7" Touch... • Answered on Jan 01, 2016
I need a charger for my tablet.
Walmart universal charger 59 bucks
11/19/2015 1:34:16 AM • Ematic 7" Touch... • Answered on Nov 19, 2015
99% charged. If plugged in it stays on. If unplugged it turns on for one second and turns off. Tried resetting it with paper clip as the manual states. Help
Hi ...just because a battery charges to 99 percent does not mean that it retains the charge as it did when new. Almost certainly need new batteies....nothing more
10/21/2015 3:51:38 AM • Ematic 7" Touch... • Answered on Oct 21, 2015
2answers
Bought a ematic 7" HD quad core tablet screen crack bought on 12-24-2015 is it still under warranty
if you bought it at a shop, take it back, its the sellers responcability to sort out a replacement/repair/or money back first, then if you get no joy then contact the manufacturer
10/7/2015 5:17:11 PM • Ematic 7" Touch... • Answered on Oct 07, 2015
Ematic 7" Touch Screen Tablet Logo
Popular Tags
95 questions posted
Top Ematic Tablets & eReaders Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Paul Bade
Are you an Ematic Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • Ematic Tablets & eReaders
Most Popular Question
change from forward camera back
  • Tablets & eReaders
