20 Most Recent Microsoft Network Programming for .Net Framework (0-7356-1959-x) for PC Questions & Answers
2answers
Microsoft .NET Framework (KB951847) not installing
  • Hi, there are a few things you can do to see if the "Software is installed. The first is to go to the Control Panel's (Programs), Uninstall a programs, you want to view that the software is present. If the software is listed? Try to (repair, or change the program). Next, open the Task Manager from the Desktop, (right) click on the Taskbar to open. In the Task manager you want to open the Services... click on the button. In the next window, scroll through the listings to find the Microsoft. Net... click to open, and see if its (Enabled; if the service is running), if not? Enable the service, Start the service, select "Apply and OK." Note: Most changes, updates, downloads.. require the computer to be restarted for the applications to take effect. "If the solution helped?, "Ratings is appreciated, thanks"
3/19/2012 8:29:35 AM • Microsoft... • Answered on Mar 19, 2012
Gak tau
can U describe the problem please?
6/16/2011 8:30:50 AM • Microsoft... • Answered on Jun 16, 2011
How to install . NET framework: v4.0.30319
Go to http://msdn.microsoft.com/en-us/netframework/aa569263.aspx and install that version of .NET.
When it is done installing, have Windows Update check for updates by typing "windows update" into the search box and pressing enter, and on the left side click "Check for updates".
This should take care of any errors.
6/4/2011 4:33:09 AM • Microsoft... • Answered on Jun 04, 2011
Net frame work 3.5 will
Cannoy install .Net Framework ... is a challenge at times.
However, we I recommend to click the link below and go through the steps in order to resolve the issue.
http://tinyurl.com/32uvluu
Regards,
Anirban Mazumdar
12/4/2010 4:46:45 PM • Microsoft... • Answered on Dec 04, 2010
.net framework installed?
You can check by going to the Add/Remove programs within the control panel or it is called Programs in Vista.
7/2/2009 12:20:59 AM • Microsoft... • Answered on Jul 02, 2009
2answers
Error that wont go away
Try first doing a system restore , if that does not work, then download and install Microsoft.NET Framework again.
1/6/2009 8:32:42 PM • Microsoft... • Answered on Jan 06, 2009
2answers
Please be careful when running any sort of tools on the registry. Since almost everything in windows has a registry entry you MUST be very carefull when doing anything to the registry. IMPORTENT : Back-up the registry BEFORE doing anything to it. The problems you are having right now COULD be because of changes made to the registry. It is hard to know because you didn't post EXACTLY what the error messages were. I can only guess what happened: 1) Possibly references to .net driver paths where re-written or deleted, A re-install of windows .net should fix this problem. 2) The path to your outlook inbox files could have been rewritten and/or possibly deleted. If you cannot find the path to these files (if they are still there) and enter that path in to the registry, then you have probably lost your local copy of your saved email. In that case there is no fix. My recommendations: 1) Always back-up, back-up, and back-up some more (you never know when something will go wrong) 2) Always take note of the exact error messages the computer gives you. It is THE only solution to any problem. Also to save you panicking, most of the registry entries regcure reports on (as with ALL registry repair tools) are NOT a problem. MOST of these entries are MRU entries (recent files applications remember), missing shortcuts, directory's and the like, nothing of which will harm your computer. You really only need to run a registry cleaner once every few months.
1/6/2009 8:21:41 PM • Microsoft... • Answered on Jan 06, 2009
Administrators pasword
Could you please provide more details on your problem. Where are you trying to log on to download?
2/4/2008 6:30:20 PM • Microsoft... • Answered on Feb 04, 2008
How to fix windows error black screen problem on Windows 7, Windows 10 and other version
Universal Fixes for All Windows Versions Basic Keyboard Shortcuts - Reset graphics driver: Press Windows + Ctrl + Shift + B - screen may flicker or beep. - Cycle display modes: Press Windows + P, then tap P again and hit Enter. - Open Task Manager: Press Ctrl + Alt + Del, then launch Task Manager and restart Windows Explorer. Windows 7 Tap .F8 repeatedly during boot. Selecgt rrpair my computer. Use Startup Repair or System Restore. Windows 10 - Wake display: Windows + Ctrl + Shift + B - Roll back display driver - Reinstall display drivers - Use System Restore - Restart Windows Explorer - Check cable connections - Disconnect unnecessary devices
8/27/2025 4:05:10 PM • Microsoft... • Answered on Aug 27, 2025
4answers
Where do I find HISTORY in Microsoft Edge
Solution
  1. Launch Microsoft Edge.
  2. Tap the Hub button at the top.
  3. Click the History option. The standard keyboard shortcut, Ctrl + H works in Edge too.
  4. You can browse your history, or wipe it entirely by clicking the Clear browsing data link at the top.
Lenovo https://support.lenovo.com > solutions > ht500009-cant...
View and delete browser history in Microsoft Edge
Microsoft Support https://support.microsoft.com > en-us > microsoft-edge You can view and clear your Microsoft Edge browsing history stored on a single device, across all synced devices, and in the cloud. You may choose to clear ...
How do I view browsing history from let's say 4 months ago?
Microsoft Community https://answers.microsoft.com > en-us > forum > all > ho... Oct 7, 2022 - Go into Edge Hub (three dots to the right of URL address bar) > History > choose History hub (three dots top right) > Open History Page > Filter . ..
8/4/2025 12:48:03 AM • Microsoft... • Answered on Aug 04, 2025
2answers
Microsoft Outlook No information error
https://www.pstrepairtoolbox.com/
  • Access all file formats used by Outlook, including OST and PST.
  • Export recovered mail to common formats, such as TXT, EML, VCL, and MSG, with the option to break recovered messages into pieces.
  • Identify and repair message text alongside attachments using advanced search techniques.
  • Check emails prior to restoration through a preview dialogue.
2/25/2025 12:06:29 PM • Microsoft... • Answered on Feb 25, 2025
2answers
Is being a Microsoft Dynamics AX developer a good career option?
You're asking the wrong group here. Call a few talent professionals or recruiters. helpful-fbhtsuujths3pkuos2jmb534-1-0_10.png
1/16/2025 5:46:33 AM • Microsoft... • Answered on Jan 16, 2025
Installed Microsoft Office XP Professional 2002 version, on my computer. the associated *********** only allows 50 uses and must be activated for full access. If anyone has the activation serial?
It is 22 years old, and is time expired on both Windows XP and probably the software. In the old days there was phone application by an automated server. It sounds like you have a trial version, and you never actually paid for it. you should be able to uninstall it, reboot, reinstall and get another 50 uses. Get Open Office instead, it is free. https://www.google.com/search?q=open+office+free ..
5/25/2024 9:00:53 AM • Microsoft... • Answered on May 25, 2024
2answers
What is the right ms
for Windows 2000 OS:: Install MS Office 2000 for Windows Xp OS:: Install Office XP , MS Office 2003 For Windows Vista:: Install MS Office 2007 For Windows 7 :: Install MS Office 2010
5/12/2024 5:18:00 AM • Microsoft... • Answered on May 12, 2024
5answers
Microsoft office Bootstrapper has stopped
tep1: - Firewall Disable The users should try to temporarily disable Firewall or other security programs on their system. Step2: - Uninstall Old version of Microsoft Office If the users have installed the old version of Microsoft Office, then they need to instant uninstall it. In any case, if the MS office does not uninstall by using the Control Panel, then they have to download Microsoft Fix Tool and then use it to remove the old version of office of their PC. Step3: -Install Microsoft Office in Clean Boot Boot the system in the clean boot and then try to install the Office 2013 program and check that the clean boot is performed to disable all startup programs and the third party services on the machine. Also, check if they are conflicting with the Office installation. Then restart the computer in Windows Clean Boot and then try to install Microsoft Office 2013 program. Step4: - Check the Services Is Running Properly The users need to ensure that the following services are running properly in the services console. Go to "Start" button and then go to "Run" command. In the command prompt, type "Services.msc" cmd and tap on "Enter" key.
  • Check the Print Spooler
  • Check the Task Scheduler & respective dependencies
Step5:- Check Internet Connection The users need to ensure that their Internet Connection to the system is properly working or not. Might require download few Microsoft utilities at distinct stages. Step6:- Repair OSE Service Follow these steps:
  • Go to Office "install disc" option, and then find ose.exe and osetup.dll.
  • Then need to create a folder for OSE: C:\Program Files\Common Files\microsoft shared\Source Engine
  • Now copy the "OSE.exe" file to that folder.
  • Then restart your machine.
  • Now try to install Office again.
3/7/2024 12:32:09 PM • Microsoft... • Answered on Mar 07, 2024
Product key for ms office 2010 -X16-32007
Not all office disks have the same codes, no matter the version you may need a whole new installation disk with the corresponding code
2/15/2024 4:22:18 PM • Microsoft... • Answered on Feb 15, 2024
My microsoft intergrated webcam works good on skpe. It will not open for me to video myself offline. can I download the same type without messing up my computer
all you need is a camera program or app that is compatible with your operating system and the computer hardware also check to see that your drivers are up to date
2/15/2024 4:21:26 PM • Microsoft... • Answered on Feb 15, 2024
I WANT THE CONFIRMATION CODE FOR MICROSOFT OFFICE PROFESSIONAL 2007 7 CHARACTERS A,B,C,D,E,F,G
2/15/2024 4:15:17 PM • Microsoft... • Answered on Feb 15, 2024
3answers
Need information about robots as an introduction?
ROBOTS
One of the least discussed topics in hobby level robotics is software. You can almost always find a hardware description, schematic, drawing, and tons of help on the electro-mechanical side of your project. However, the software, which admittedly is one of the hard parts, eludes many people. In this article, I would like to demonstrate how to structure your software so your robot will function properly.
I would also like to point out a great technique for getting started. Many software engineers make heavy use of something called 'Pseudo Code'. This is a technique where you write your program in half programming language and half human language (English, Spanish, Driud, etc). Pseudo code is very useful for getting the layout of your program ready, to get basic algorithms worked out, and to be able to read your 'code' quickly. I will demonstrate this technique a little later.
As for programming languages, it doesn't matter which language you choose to use. I personally use the 'C' programming language the most. BASIC, Assembler, or FORTH are all fine choices. It turns out that the language is a small part of the structure of your program. The software has a job to do, and the key is to get it done! I am going to write this article in SBASIC, but the techniques are the same no matter which language you choose. SBASIC is available from Karl Lunts website at http://www.seanet.com/~karllunt/tips.htm.
GRAPHICS
Basic Graphic Design Principles Part 1 Lines and Shapes
by Kelly Paal
This is part one of a two part article.....click here to read part 2. As a graphic designer, you need to know the principles of graphic design in order to design at your best. Knowing what the design principles are will help you implement the best layouts and help you become aware of what you have done wrong in your past designs. This article details information regarding graphic design as it pertains to lines and shapes.
PC JOBS
Types of Computing Jobs
  • Data Entry - This is a job just about anyone can get. Basically, you take information from a piece of paper and use it to fill out a form on the computer. Many old hands who started out in this role are now heading up computer departments.
  • Secretarial/Administrative - This position involves some basic office skills. Not only must you understand the basics of using your computer and a few applications, but you'll probably also be expected to take dictation, answer phones, type letters, and keep things organized. In terms of computer skills, you should know how to use word processing, accounting, and spreadsheet programs at the very least. People in this role often move into other computing roles such as Managers, Meeting Organizers and Human Resources. Naturally you can move into mainstream computing areas, particularly QA and Testing.
  • Power User - Not so much a position as a status of being an extremely proficient user of (typically) Microsoft Office or similar tools. Advanced users of these tools become familiar with the basics of computer programming through starting with Excel macros or Access database programming. One can become very valuable to a small business by learning such skills, and even start to consult with other small businesses at rates typically starting around $50 an hour.
  • Customer Service/Telesales - These positions usually place a higher emphasis on phone skills than computer skills, but you should know at least the basics of how to use your computer.
  • Technical Support (Production Support) - Most companies consider technical support to be an entry-level computer job. You are expected to know the operating systems on which the product you'll support will run, and you'll also need to know the basics of any programs that product might interact with. The good news is that the company will teach you what you need to know about their products - you just need to learn everything else. Success in technical support requires good problem-solving skills and a great deal of attention to detail. Technical Support and Problem Management is a rapidly growing area. Users now rely heavily on Help Lines, International Support Centers and the like.
  • Software Quality Assurance (SQA) Engineer - You need to know as much as the best technical support personnel. You need to be a problem solver, a detective, and sometimes even a Customer Service representative. You'll also need some basic programming skills, since more and more companies are beginning to rely on automated testing. The best SQA engineers understand a little (or a lot) about every aspect of computers, from building them to using them to programming them.
  • Software Engineer (Developer or Programmer) - To get a job at a top software shop such as Microsoft or Google, you'll need a degree in computer science and detailed understanding of the field. However getting a developer position in some small company may be easier. What do you need to know is the language in which you'll be programming. It is also important to know database fundamentals and (if programming for Windows) the Windows API. Knowing more than one programming language is very helpful. Understanding many of the basic fundamentals of computer science (e.g. linked lists, arrays, pointers, object oriented programming) will be essential in demonstrating your proficiency.
  • Business Analyst (Analyst or Systems Analyst or Analyst/Programmer or User Analyst) - This is a relatively new title, but the role is as "old as the hills". People can become a BA with any mix of business and computing skills. It is really a matter of looking at what the company is really after. A good BA should know the process from end to end. The BA is primarily the connection between the business and the developers. To get into this job, and into computing, good knowledge of a business is helpful. So, if you gain good knowledge through your job, and maybe do a computer course, you can get your foot in the door.
1/23/2024 8:20:10 AM • Microsoft... • Answered on Jan 23, 2024
2answers
Please i want source code calculator using asp.net
i want the source code for simple calculater in asp.net
1/8/2024 10:28:36 AM • Microsoft... • Answered on Jan 08, 2024
Microsoft Network Programming for .Net Framework (0-7356-1959-x) for PC Logo
9 questions posted
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Microsoft Computers & Internet
Most Popular Question
install net framework v4 0 30319
  • Computers & Internet
