Canon PIXMA MX850 Multifunction Printer Logo
Posted on Jul 22, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm getting an error code of "5010" - Canon PIXMA MX850 Multifunction Printer
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Jul 22, 2011
Anonymous
Expert
Level 2:
Answers
109
Questions
Helped
56860
Points
388
Pls do the following
1. power OFF the printer
2. Unplug the printer's power cord from the electrical source.
3. Wait AT LEAST 1 minute - no less than 1 minute.
4. After 1 minute, plug-in the printer to the electrical source. Turn on the printer - wait for it to warm up as usual and it should be ok...........
Thank u..............
What are the error codes on my printer,5010 & 6100?
The 5010 error indicates a scanner error. The scanner unit cannot detect the home position, or the scanner unit warming-up is not done properly at power-on. On the LCD, "Scanner is not operating correctly." is displayed.
The 6100 error indicates a logic board error. The check sum value is incorrect in the ROM check at hard-power-on.
Fixing these errors is more expensive than replacing the printer. Sorry.
Fixing F
I can't make my canon mp460 do anything. little used i've just taken it out of it's box again and changed the ink cartridges but nothing. error 5010 showing.
hi
"Issue: ERROR LCD: Error Code 5010
Solution: Press ON/OFF switch to reset the multifunction device
Reset the device when it is not functioning properly.
If the device is not functioning properly or to clear memory, reset it.
1. On the operator panel, press and hold the button for one second. (The display will go blank.)
Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
2. Wait approximately ten seconds and then press the button again.
3. Wait until the device has completed its cycling process before submitting another job request."
or
go to following link you will have more solution
http://www.subnixus.com/error-codes/error-5010.html
Multifuncional mp140, result error 4,2 and then error 5010 solution?
canon mp140 i get a error code 5010 any suggestions on how to fix this?
49helpful
3answers
4helpful
2answers
Canon pixma mx700 error code 5010
5010 is a scanner error from the scanner on top. Canon has no parts for these and you can only replace the entire top of your machine. If you can get it apart, you might clean and lube, but it's not made to be opened.
10helpful
Printer will not print, error code 5010 is
5010 is a scanner error, either worn out scan lamp or sensors. Canon only replaces the entire scan assembly, if you like I can get part number and price.
Re: Error Code 5010
Call Canon technical support.
Dial 1-866-261-9362, Monday - Friday 10:00 a.m. - 10:00 p.m. ET (excluding holidays).
See also a previous related question here! (a scanner issue)
http://www.fixya.com/support/t1232529-error_code_5010_cannon_mp460_printer
2helpful
Error code 5010
There's no specific info on a 5010 error even on Canon website, but ANY error in between 5000-9999 needs Canon's attention, so if it's under warranty, get a replacement.
6helpful
2answers
Error code 5010
comme caz.... si po agiustare sta mer...????
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
