Microsoft Windows XP Professional Logo
Posted on Jun 13, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to setup proxy server - Microsoft Windows XP Professional
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 68 Answers
  • Posted on Jun 22, 2011
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
68
Questions
0
Helped
9180
Points
173
To set up your system to use a proxy server, right-click Internet Explorer, click "Properties." Click the "Connections" tab and click the LAN settings button (near the bottom). Click the check box under the proxy server setting and input your information. If you need a list of IP proxy servers, try http://www.hidemyass.com
How to Connect to a Proxy Server?
open control panel/ click internet options/ click the connections tab, then at the bottom click LAN settings . Un click use a proxy server , then click automatically detect settings.
you have not said what windows you have or what setup you have got.
but try this out.
tip
How to access facebook at school when blocked
In this article I will go over different methods of accessing facebook when it is being blocked by your school for example. None of these methods are guaranteed to work. This article can be used to access blocked sites in general.
FreeGate
1) If you are able, go to google.com and download Mozilla Firefox. It is a internet browser.
2). Using Firefox, go to google and download/install a program called Freegate.
3) Install the program and follow the instructions it gives you to setup the configuration. You will be changing some proxy settings.
Make sure that freegate is running when you are using firefox.
Switching to HTTPS
1) If you are at school, and you go to http://www.facebook.com, and it is blocked, you can try adding a "s" to http. What this does is switch from a standard connection to an encrypted one. Some administrators will not block a secured connection. Just simply add the "s" so it is https://www.facebook.com
Online Proxy
This basically hides your online movements. It is less likely to work as administrators will block sites with the words "proxy" and or common proxy sites.
1) You may be able to use an online proxy to go to facebook. The links below are to some of my favorite online proxies. Just simple go to one, enter in the URL address(in this case http://www.facebook.com) and it should take you to the website.
Click here for Zend2 Proxy
Click here for HideMyAss Proxy
CTunnel
This site has some really aggravating ads, but if you can look past that it is decent.
1)If you can access this website, you can use it to visit facebook.
Click here for Ctunnel
Setting up a private proxy server with SSL
This step is more in depth, but the pay off is that you will have your own private proxy server with SSL encryption you can use to visit any site you want without fear of being blocked or your traffic viewed. Very ideal for anonymous web browsing.
For this method, it is recommended to setup a proxy server on a Linux based computer, however, you can use Windows. Once you have a private server set up, you can set your proxy configuration in firefox to use your server.
You can read more about this step by visiting the link below.
Click here for instructions
Foxy Proxy Download
Alternatively, instead of creating a server you can pay to use one or maybe you know someone with a server. A simple google search of "proxy servers" can yield the results you want.
I hope this article was informative. Be sure to pay attention and do your class work :)
Regards,
G33k
Where can I find my proxy
Did you look under the computer?
Of you don't know what a proxy server is, no need to look for it.
Don't go into network details if you don't know where to look for.
Don't use a proxy or proxy settings, because normally you don't have a proxy. you only have a proxy, if your provider or admin tells you. SO please don't try tp setup any.
I want to block facebook for all the lan users.
Setup a proxy server and black list facebook.com that is the easiest way. Route all users to the proxy server and set premissions that does not let them change the proxy settings.
Cannot connect to yahoo says lan or proxy settings or virutal ip server not working
Do you have a proxy setup?
In Windows...
1. Control Panel
2. Internet Options
3. Connections tab
4. Lan settings button
Do you have a proxy setup here? If so remove it.
Restart your computer if you haven't already.
Hope this helps!
How can i go to facebook at school
your school probably has a firewall set up to block certain sites.
You would need to set up a proxy server to get around this.
I would look to google app engine since it requires little technical knowledge.
You can read how to set it up here.
http://www.labnol.org/internet/setup-proxy-server/12890/
How do I set up my own elite proxy server?
Setup your own Proxy Server in 5 Minutes for Free var google_adnum = 0; function google_ad_request_done(google_ads) { var u = ''; var i; if (google_ads.length == 0) { return; } else { for (i = 0; i ' + google_ads[i].line1 + ' ' + google_ads[i].visible_url + '
' + google_ads[i].line2 + ' ' + google_ads[i].line3 + ' '; if (i '; } u = 'Ads by Google ' + u + ''; } google_adnum = google_adnum + google_ads.length; document.write(u); return; } google_ad_client = 'pub-3152670624293746';google_ad_output = 'js';google_ad_type = 'text';google_feedback = 'on';google_language = 'en';google_encoding = 'utf8'; google_max_num_ads = '2'; google_ad_channel='9126605320'; google_skip = google_adnum; google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); Ads by Google Google Analytics www.google.com/analytics
Understand how people find, explore & convert on your site - Now free. google_proxy.jpg
A simple Google search and you'll find dozens of really good PHP scripts on the Internet to help you create proxy servers in minutes for free. The only limitation with PHP based proxies is that you require a web server to host the proxy scripts and second, you also need a domain name to act as an address for your proxy site.
If you don't own a domain or server space, you can still create a personal proxy server for free and that too without requiring any technical knowledge.
Create a Free Proxy Server with Google App Engine Here's one such proxy site that you can build for your friends in China or even for your personal use (say for accessing blocked sites from office). This is created using Google App Engine and, contrary to what you assume, the process is quite simple.
Step 1: Go to appengine.google.com and sign-in using your Google Account.
Step 2: Click the "Create an Application" button. Since this is your first time, Google will send a verification code via SMS to your mobile phone number. Type the code and you're all set to create apps with Google App Engine.
Step 3: Choose a sub-domain* that will host your proxy server. Make sure the domain is available, agree to the Google Terms and click save. The sub-domain is also your App ID that will uniquely identify your proxy application.
For this example, we'll use labnol-proxy-server as the App ID though you are free to choose any other unique name.
Step 4: OK, now that we have reserved the ID, it's time to create and upload the proxy server application to Google App Engine. Go to python.org, download the 2.6.4 MSI Installer and install Python.
1_create_app_engine_account_thumb.png 2_verify_mobile_thumb.png 3_authenticate_thumb.png 4_create_application_thumb.png
install_python_thumb1.png install_app_engine_sdk_thumb1.png sdk_preferences_thumb.png
2answers
I have a DSL line from Airtel, and my Zyxel P-600 works OK on a single PC. But when I use it on LAN, it doesn't work. Please help.
Hello manishbillor,
Have you tried using a proxy server on the computer that's connected to the ZyXel P-600? Using a proxy server makes it possible to share an Internet Connection on a LAN. A good free proxy server can be downloaded from the analogX web site:
http://www.analogx.com/contents/download/Network/proxy/Freeware.htm
The browsers on the other computers need to be setup to use the proxy server machine address. Search for 'proxy' on the browser's help menu option to determine how to do it (very simple).
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
1helpful
Yahoo messenger not working ........some problem with system configuration it says.even reinstalling dosent work.
  1. Click the Tools button, and then click Internet Options.
  2. Click the Connections tab, and then click LAN settings.
  3. Select the Use a proxy server for your LAN check box.
  4. In the Address box, type the address of the proxy server.
  5. In the Port box, type the port number.
  6. If your network requires separate proxy addresses for different services, such as HTTP, HTTPS, or FTP, click the Advanced button, and then type the individual proxy server addresses to use.
  7. When you are finished making changes, click OK until you return to Internet Explorer.
  8. Or go to advanced menu and click default setup
1helpful
2answers
Download MAil From JAna SErver
Hello Sir,
As my internet is shared through cc proxy
I have to put proxies to all of my programs so that they can run.
Unfortunatelly the only one I cannot get running is outlook express.
When I try to edit the outlook proxy settings it sends me to Internet Explorer's settings
(which makes me think that outlook and internet explorer share the same proxy settings).
The strangest thing is that IE runs with no problems
but outlook express cannot connect to the server.
It says that the server cannot be found (both incoming and outgoing)
Could you please advise me how to make the outlook running.
Also I had try to install squid 2.7 proxy on win2k8 but i m getting some error with squid service is not runniong on win2k8 it says create services failed ...please advice me which proxy server i can use our network ( my task is only i want 2 secure internet & block some sites on my internet and outlook should be a work )
Thank you very much.
Have a great day,
Regards
Ashok
Top Microsoft Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
