Google Chrome Logo
Posted on May 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server connection failed.
Anonymous
Level 2:
New Friend:
  • Expert 113 Answers
  • Posted on May 19, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
113
Questions
0
Helped
27287
Points
373
Go to Wrench menu > Options > Under the Hood > Change proxy settings > LAN Settings and deselect "Use a proxy server for your LAN."
  • Anonymous Nov 14, 2011
    I finally resolved the problem to downloading Adobe Player 11, but it was a strange way to make it work, but it DID work! While I was on my wireless isp, I kept getting "ERROR 130", so I downloaded a free dial-up program and even though it was slower, I did manage to get Flash Player 11! I also D/L java update 27 which I also could not get to D/L when I was on my wireless!?(Go figure??)Well, lo & behold, it also updated and after completing both, I deleted my dial-up, closed all programs, rebooted, and had my Flash Player 11 & java update 27(not that I really needed it), so I went to Steve Gibson's free "Shield's Up", which checks out your main 1056 ports and received a "Tru Stealth" Pass grade(Means my computer does not exist!! Which is AWESOME!!) which is a good site to check out your important ports and makes sure no malware or virus entered, not to mention leaving a port open for hackers! Anyway, it's a great work around if you can't download something (or update it to the latest level) and need to get past that annoying "ERROR 130" message! May you have as great a luck as I have! BTW, you can find a free dial-up service for this type of help! Not like your going to keep it! Kudos to the tech wizards at Vista Forums for this neat trick! Worked like a charm!!
5 Related Answers
Anonymous
  • 2296 Answers
  • Posted on Dec 15, 2010
SOURCE: Error 130 (net::ERR_PROXY_CONNECTION_FAILED): Proxy server
The error that you get indicates more of a proxy problem than a virus problem. If you are behind a proxy, you have to have this added to your Chrome shortcut, in the Target field after the location of Chrome: --proxy-server="proxy:port" where proxy is the address of your proxy and the port is the port number.
If you think there's a virus, follow instructions from here to clean your computer from viruses http://www.fixya.com/support/r7263144-clean_computer_from_viruses
Once you cleaned up your PC, if your copy of Chrome is still corrupt, or it's not working, try to remove it and install it again. Here's a link to the download page http://www.google.com/chrome
paul4265
Paul Pope
  • 592 Answers
  • Posted on Dec 18, 2010
open google chrome
to the right of the address bar is a wrench icon, click on it.
almost at the bottom of the list it says options, click it
click on the tab that says " under the hood "
next click the button that says change proxy settings
in the next box that pops up, click on "never dial a connection"
next click on the LAN button
next ensure that all check boxes are clear, with no checkmarks in them
click ok
then click ok again
that should bring you back to the google chrome options box
click close
close out chrome
wiat about 10 to 15 seconds to allow for chrome to recognize the new settings
reopen chrome and you should be able to use it just fine
Anonymous
  • 812 Answers
  • Posted on Jan 01, 2011
SOURCE: error 130 (net:err_proxy_connection_failed): proxy server
Hello i hope u 'll be fine.... thanks for using fixya.
Follow these steps
Open Google chrome >>To the right of the address bar at the end is a wrench type icon click on it >>Almost at the bottom of the list it says options click it >> click on the tab that says "under the hood" >> next click the button that Change proxy settings >> in the next box that pops up click on "never dial a connection" >> next click on the LAN button >> next ensure that all check boxes are clear, with no check marks in them click OK >> then click OK again that should bring you back to the Google chrome options box >> click close
Then close out chrome now wait about 10 to 15 seconds to allow for chrome to recognize the new settings >> Reopen chrome and you should be able to use it just fine
I hope this solution will helpful 4 u. Best of luck
Please keep thumbs up in do rating
THANKS & Keep using fixya
Anonymous
  • 812 Answers
  • Posted on Feb 07, 2011
Hello i hope u will be fine, thanks for using fixya.
Follow these steps
See my this Solution (Same as yours), 14 people thought it was helpful for them
See my TIP & TRICK foe this problem
Please don't forget to click on Four thumbs which are given below if it is helpful
THANKS & Keep Using fixya
Amit Awasthi
  • 89 Answers
  • Posted on Dec 08, 2010
Do you normally use a Proxy??? If not, then yes, it's most likely a virus that sets proxy settings, directing all your network traffic through the hacker's proxy. There, they capture all your internet traffic including login IDs and passwords.
If you have no idea how long this has been going on, then they have all your information already. Hacker proxies get shut down fairly quickly, hence the error you are seeing now. However, the damage may be done already.
Do a full virus scan, then go to all your online sites and change all the passwords - soon!
Top Google Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Kolbrun...
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
