MSN Message error 80048820, unable to signin
Problems:
- While you try to Sign in MSN Messenger you getting an error message with the no. 80048820
- Unable to Sing in
Probably reasons-
- Your system time/date incorrect
- Internet Proxy setting incorrect
- softpub.dll disable/missing
- Firewall does not allow to access, etc.
Solution-
Step#1
- Remove Internet Explorer proxy server settings and check the 'Automatically detect settings'.
- Launch Internet Explorer, click "Tools" and then click Internet
Options. From the Internet Options dialog box, go to the Connections
tab. Click LAN Setting. Uncheck the Use a proxy server for your LAN
checkbox. Finally tick/check: 'Automatically detect settings'.
Step#2
- Correct the computer system's Time/Day as current (if required).
Step#3
Click Start (Button), and then click Run, type regsvr32 softpub.dll click ok.
Step#4
- Turn off the firewall. Check firewall settings such as Norton: "Block
access to secure sites". If this cures the problem, make sure that
Microsoft's MSN Messenger is allowed full access through your firewall.
Reference from:
http://www.trulybangladesh.com/itnews.php
SOURCE: error code 80048820
Please see below for instructions on how to troubleshoot
http://www.computerperformance.co.uk/Logon/code/code_80048820.htm
If this solution has helped you, please take the time to rate me.
Internet Explorer - Try removing the tick next to Internet Explorer 'Proxy server' settings, instead, go with the 'Automatically detect settings'. 167 views
thank you very much it has been doing this for a week now and driving me insane
