SOURCE: The paper tray does not
is this on a cr machine if so the harness between the tray and the machine is broken
SOURCE: Paper tray will not lift on a GR3770
either the motor is not turning to lift it up or the gear is broken, do you hear the motor turning when the tray is pushed in? take the tray out and look in the back to see if there is anything blocking it also.
SOURCE: Canon Pc 25 not pulling paper completely through from tray or from manual feed tray.
hi,clean feedrolls & paper transportation.clear any misfeed sheet in paper supply section.send me result.
thank you.
SOURCE: I have a FR2910. When the tray lifts to start
I couldn't find this problem reported on the net, but I did come across an interesting blog about a sensor problem on a different model Riso- but since I suspect a sensor error here, it could be relavent:
http://www.copytechnet.com/forums/digital-duplicators/17418-riso-rz-220-a.html
It's either a gear or sensor issue, but I suspect a sensor.
I'm still trying to run down a service manual for you, but there is a different model manual on this site, and it's free, so it might help clue you in if it's close, or has similar sensors:
http://www.eserviceinfo.com/service_manual/datasheets_r_500.html
Of course, the gear mech in the tray assembly could be strung into a different configuration, and that would require a service manual to fix, and a lot of patience.
Here what one fellow said on copytechnet.com:
If anyone is having trouble with their riso I recomend buying one of the CD manuals sold on ebay, and then downloading a hard copy of the manual for their machine.
There are a bunch of test codes that are really helpful, but I wish Chilton's had a Riso manual
That's all I could run down, and I never worked on a Riso, so I can't offer any insight, but since this problem wasn't reported, it must be some tricky sensor or tray feed issue.
I found this link for a "technical manual" which might be useful to you:
http://www.nodevice.com/manual/riso.html
Hope this helps, and thanks for using FixYa.
SOURCE: We have a gr 3750
I had the same problem when I tried to replace the separation pad with a different one. The new one was too thick so Riso thinks it has a paper jam, and there is no error code on the panel for it. Just says clear paper jam and reset.
So you must have a similar problem in the area of the separation pad? It could also be the sensor in that area is bad or out of adjustment. I think it has to be one or the other.
how can solve
