What laptop when do you see the code 10? what os code 10 usually means a faulty issue with a driver go to device manager
windows xp right click my computer - properties- device manager anything with a yellow or red mark is your issue try and roll back the driver or update the driver. you can find the driver from your pc makers website
under vista or 7 go to computer , sys prop. device manager and do the same
If you run into the error "This device cannot start. Code 10? (often
followed by a driver identifier, for example "This device cannot start.
Code 10 in audio driver"), here is what it means.
The Windows error "This device cannot start. Code 10? or "This device
cannot start. (Code 10)" is a hardware error that most commonly means
that you have a bad, missing, or incompatible device driver. So, for
example, "This device cannot start. Code 10 in audio driver" means that
you have a bad or missing or incompatible driver for your sound card.
The technical explanation for this message, according to Microsoft, is this:
"If the device has a FailReasonString value in its hardware key, that
string appears as the error message. The driver or enumerator puts this
registry string value there. If there is no FailReasonString in the
hardware key, you receive the following error message:
This device cannot start. (Code 10)"
What does that mean in plain English? It means that if the device which
is throwing the error has added its own custom error text to your
Windows system when the device was installed, then when the device
encounters an error, you will see the custom error message specific to
that device. But if it doesn't have its own custom error message, then
Windows uses its own generic error message for devices, which is "This
Microsoft recommends that when this happens, you click "Update Driver"
to update the drivers for the device. You can also start the Windows
troubleshooting wizard by going to the general properties tab of the
device, and clicking on "Troubleshoot".
Before doing this, be sure that you have the correct and most up-to-date
versions of the driver(s) for that device. You can also try
uninstalling and reinstalling the device, using the disk which came with
it.
Finally, you can go to the website of the device's manufacturer, and
check their downloads or support section for current, up-to-date
drivers.
