Hi
there you
have the error code 51030, you can fix all error codes easily This
needs to be repaired. you
can send the console to Nintendo for free if in warranty, if out of
warranty then this will cost you around $150, the whole process will
take 4-6 weeks I
prefer the Wii repair
guide Method, download the guide and follow the simple step by
step instructions and fix the problem in less than an hour, no
hassle, low cost everybody is happy. Best
Regards
WiiRestore Feel
free to leave a comment if you need assistance
If your getting error 51030 try thishttp://howtofixstuff.blogspot.ca/2013/08...
SOURCE: error code for accessing internet 51030
Hello :
The only wireless network within range of your Wii console is not configured or is not compatible with the Wii.
If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting.
Check for interference that may be preventing a successful connection..
Check to see if the router you are using is a known to be incompatible. . If your router is known to be incompatible, we recommend using a different router if possible.
Make sure that the SSID (network name) matches exactly to what you have entered in the Wii console's settings
I hope that will help .
rate please !. .
SOURCE: error Code:51030 Unable to find an accesspoint.
most efficient and best way is to download all the
repair guide and keep it in our system, we can use this for our personal future
use...
click here to download repair guide
Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
