Ovens Logo
Anonymous Posted on Mar 06, 2011
Kitchenaid error code double electric oven F2 E0 starts then shuts down, originally statred having trouble after auto cleaning
3 Related Answers
Anonymous
  • Posted on Sep 25, 2010
SOURCE: kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Anonymous
  • 15935 Answers
  • Posted on Oct 01, 2010
SOURCE: Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
espressonist
espressonist
  • 1711 Answers
  • Posted on Feb 23, 2011
SOURCE: Error code of E1 F2 on a kitchenaid double wall
F2 - E1
Keypad cable unplugged
1.
Check keypad connector for firm connection (keypad connects to control
board).
keypad (also called touch pad or membrane switch). Some models incorporate
keypad in to control board as one unit. In this case, replace control board
(also called ERC or clock).
Top KitchenAid Ovens Experts
jdthefixer
Sudeep Chatterjee
Sudeep Chatterjee
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
