Posted on Mar 01, 2011
SC 990 error code. Functional problem detected.
5 Related Answers
Anonymous
  • 38 Answers
  • Posted on Oct 22, 2008
SOURCE: Functional Problem with RICOH Copier Error No-SC:541
YOU NEED TO RESET THAT CODE
A
Anonymous
  • Posted on Apr 26, 2009
SOURCE: I have a Savin 2513 and when i turn it on i get an
This error relates to the scanner.
If you open the the document cover and turn on the main power, wait for the machine to begin it's warm up cycle, the scanner moves back an forth to get into it's "home position", do you see the green light, light up? If not, that is the likely problem.
However, these are other possible causes. All of which will require a tech:
- Defective exposure lamp
stabilizer
connector
- Unclean scanner mirror
- Scanner mirror out of position
- Defective SBU board
- Defective SBU connector
- Lens block out of position
Ickoajnc
OfficeServiceAjnc
  • 215 Answers
  • Posted on Jul 11, 2009
SOURCE: error code SC 546 in Ricoh 2045e
It's fusing unit but the thermistors connection can be good, but check do they are touching the surface of the hot roller and check do on the side where they are in touch with the surface of the hot roller has some attached toner on them.
Anonymous
  • 21 Answers
  • Posted on Oct 21, 2010
SOURCE: Sc 990 ERROR PROBLEM ON
replace drum, drum cleaning blade,charge roller. this will sort Sc 990
Anonymous
  • 263 Answers
  • Posted on Feb 17, 2011
SOURCE: I have a ricoh 2051
After turn the main switch off and on the error appears again????
This error means that there is a bad comunication between the controller board and the operation panel.
Did you intervew in the machine? Some tecnical intervewing?
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
