Electronics - Others Logo
Posted on Feb 16, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cannot format usb write protected transcend - Transcend 4GB JetFlash 110 USB 2.0 Flash Drive (TS4GJF110) Media
Brian Sullivan
Level 3:
  • Transcend Master 27,725 Answers
  • Posted on Feb 16, 2011
Brian Sullivan
Transcend Master
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps
don
I HAVE A FLASH Transcend (Jet Flash V15) 4GB I CAN NOT USE IT WHEN TRY TO COPY A FILE TO IT A MESSAGE APPEAR THAT THE DESK WRITE PROTECTED AND TRY TO REMOVE THE WRITE PROTECTION I TRY FORMAT BUT NOT WORK...
1.Close all files
2.Select Transcend Pen drive-Right Click-Format-ok.
3.After formatting you can copy all files upto 4GB.
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Hi its AKSHAY I HAVE 4GB TRANSCEND PEN DRIVE AND I HAVE TRYED EVERYTHING BUT ITS STILL WRITE PROTECTED WHEN I TRY TO FORMAT IT
try using this software to format it.. www [dot].transcend [dot] nl/support/dlcenter/ORT_Software.asp?Link=OnLineRecovery.exe
7helpful
3answers
How to remove write protect on my 8gb transcend jetflash
If you dont have any switch for 'write protection' in the USB body, then download the utility called 'Jet Flash Recovery Tool' from trancend web site. It could help you.
Please come back and rate my solution if it turns to be helpful for you. Thnx
16 gb transcend pen drive write protected
Mine is Zero byte. HP USB Disk Format Utility/ Editing registry / Format from Dos are useless.
1helpful
Cannot format diskrive because it is write protected
first open control panel then open computer management and than disk management than right click on pendrive option and format it
6helpful
I cannot remove write protection of my transcend 4GB pen drive
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW.EXE
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
5helpful
I have Transcend JF V30 2GB pendrive i m unable to format
go to transcend website and download Jet Flash Recovery Tool and format ur pendrive...... :)
I cant format my transcend usb 2gb it says write protected
Hi
The pendrive seems faulty or corrupt but there might be a possibility that you recover functionality. I think you might be using XP or VISTA. Whichever the OS use another computer with A DIFFERENT OS (so if its XP go to Vista or vice versa) and FORMAT it. You should be able to get your pendrive working again. If not it is tough luck time!
Cheers
I cant format my transcend 2 gb pen drive it says write protected
do you see any switches on the side of it ? if so move it to the other position and try again.
I can't format my 2 gb transcend pen drive it saya write protect
Some usb drives/flash drives have a little switch that locks it and makes it read only to avoid accidentally losing important files. Try looking for a small switch somewhere on the case of the drive and switch it to the other position if you find it.
Top Transcend Electronics - Others Experts
Sudeep Chatterjee
Sudeep Chatterjee
Larry
laikexpert
laikexpert
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
