Hi iba bob...
You can unlock by 2 methods
1)you can get master code from
http://www.unlock-zone.com/
or
http://www.nokialockcode.com/mastercode.php
and
superunlockcodes.com/unlocking-services/rs12wp6/ (You have to pay for these)
2)You can flash(format) your handset to reset code 12345
(formating delete all data including messages,contacts,etc... So i suggest you to back up all the files before formatting You can back up file using Nokia PC suit)
To back up your files
*Install the Nokia PC suit
*open Nokia PC suit >Select Back up
To restore Backed up data
*Open PC suit>Tools tab>Restore>Select Restore>select a restore point(restore point is file in which all data's are saved)>Ok and wait for 5-10 mins.
To flash you need
*USB cable compatible with your handset
*A Computer
*Nokia PC suite of your handset
*Internet connection(Min speed 1Mbps)
*Nokia software updater(you can download by using Nokia PC suit)
To flash
*Install the PC suite
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokia Software updater by selecting this option)
*Install the "NOKIA Software Updater"*Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
Try the follwing.... *check whether your phone or memory card memory full or not If memory is full clear some memory
*Scan with a updated version of updated antivirus
If problem persists you need to flash your handset
To flash you need
*A Computer
*PC suite of your handset
To flash
*Connect to USB
*Open the PC suit
*Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option)
**Don't disconnect while updation process
Than you have a nice day...
Please try 12345. If fails , get it unlocked at www.unlock-zone.com
