Accessory Export Kyocera Loft / Torino S2300 Premium Leather Carrying Case + rubberize Hard SnapOn Case Cover+ LCD Screen Protector + Rapid Car Charger for Kyocera Loft / Torino S2300 Logo
Posted on Jan 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a default passcode number? - Accessory Export Kyocera Loft / Torino S2300 Premium Leather Carrying Case + rubberize Hard SnapOn Case Cover+ LCD Screen Protector + Rapid Car Charger for Kyocera Loft / Torino S2300
  • Anonymous Feb 06, 2012
    Try this: Last Four of the Phone #... Worked for me!
Anonymous
Level 2:
New Friend:
  • Expert 56 Answers
  • Posted on Feb 11, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
56
Questions
0
Helped
8266
Points
133
What is the default passcode for iphone 3gs
Generally, the default passcode can be 1234 or 123456, and the digits rely on the blank number. This small trick is useful and some users are fond of this method. This solution can be workable and effective to help you to unlock iPad passcode without restoring.
However, if this doesn't work, check: Fixed: iPad Asking for Passcode I Never Set
4helpful
2answers
Acer Extensa 4630Z passcode for bluetooth
Passcode is the temporary code for wireless devices when pairing with each other to establish a secure connection. You can assign any numbers or codes you like for the connection to take place. Suppose when you are asked to enter the passcode, enter 123 on the computer's passcode box and then same 123 on the cellphone. It'll automatically accept, but you need to assign the passcode everytime you connect the devices (as I've mentioned for once connection only).
You can assign any numbers or letters as passcode, but it should be set the same code on both the devices.
Good luck.
Thanks for using FixYa.
2answers
I locked my Nokia 2680 and forgot my passcode how can i unlock it?
If you actally set a differenr passcode, then you can do a complete system reset from the security screen. If you never set a passcode, then the default passcode is the last 4 digits of your cell phone number.
4helpful
What is the unlock code for a samsung blackjack ?
In order to 'pair' one Bluetooth device to another, a passcode has to be exchanged between the two devices. When you first connect, one machine will ask you to enter a passcode... enter any 4 digit number. The other device will then ask you for a passcode. Enter the same 4 digit number. It doesn't matter what the passcode is, as long as you enter the same number at both ends.
sometimes as default the code is 1111 ,1234,9999,5555 so you need to try them you can try them as many times as you want .
hope this helped let us know how you get on
2answers
Unable to pair with phone, needs the passcode for motorola H700
try The default settings Of 0000
Or 1-2-34.
Mike @ compurepair.
1helpful
Passcode
The default passcode is 0000. Make sure you are in number mode if you are pairing to a BlackBerry.
24helpful
5answers
Don't know the pin to set up my bluetooth
Most Motorola bluetooths have a default passcode of 0000 and cannot be changed.
39helpful
6answers
Bluetooth passcode
All bluetooth have a default passcode of 0000
17helpful
4answers
Unlock LGVX8300 passcode
Try dialing *228, then pressing 1. This reprograms the phone to factory defaults, making your security (lock) code the same as the last four digits of your phone number. For example, if your phone number is (315) 123-0101, then after following the above instructions, your passcode is now "0101". *228 is accessible EVEN when the phone has been locked. This method does NOT delete contacts or change your phone number. All of that information remains the same as before you dialed *228. Also, you do NOT need to remember your old passcode for this to work.
How do i reset the passcode for my pitney bowes 9920 (Panasonic UF770)
The default passcode is the model number. I don't know how to change it.
Top Accessory Export Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
john h
Are you an Accessory Export Cell Phone Expert? Answer questions, earn points and help others
