Dehumidifiers Logo
Posted on Jan 20, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MODEL DM 162EBS. Why is it when I switch my dehumidfier on 10 minutes later it goes to defrost. [ WHY?]
Mack Baxter
Level 3:
Master:
  • Master 383 Answers
  • Posted on Jan 20, 2011
Mack Baxter
Master
Level 3:
Master:
Answers
383
Questions
Helped
77015
Points
1139
Let's think thru the dehumidification process--
A dehumidifer needs to create a COLD surface, on which to condense the moisture in the room.
If your room is quite cool, it is esily possible that the COLD surface can go below freezing-- Now the water is trapped in the ice-- So-- it has to defrost, to melt off the ice, and start all over again!
Can you move the Dehumidifier to a warmer spot-- maybe near a radiator, or a heat register? -- You will remove much more moisture in that way, too..
Just a question: Most homes are WAY TO DRY during the winter months-- are you sure you need to dehumidify your living area? (Maybe you are drying the basement?-- or a wet area?)
Just seeing if I can help
Mack B
My Danby dehumidfier model DDR2510E showed the code E2 after I emptied it and now won't work and no where in my manual does it say what to do or what it means.
Hi There,
The E2 error you are receiving is likely the float switch sensor when turns the system off when the bucket is full. Please contact our customer service department to be connected with a service depot in your area.
1-800-263-2629 Business hours are Monday to Friday 9am-4pm
Thank you!
1helpful
When Dehumidfier is on for 5 min it stop and CH apears but the tray is not full
it appears the float switch is full of water(the float) try empting it(they usually just screw off)if you can find a replacement change it..make sure to un plug any electrical item before messin with it ok!?
My dehumidfier won't shut off. I check everything out and it's good but it just won't shut off it keep running.
It may be, that you have it running in continuous mode, rather than timed mode. Also, most dehumidifiers fans will run almost continually, to keep the air moving, so the humidity sensor can pickup and increase in humidity, if there is one.
If the above doesn't seem to be the problem with your unit, turn The Master ON/OFF Switch to OFF and unplug the unit for 12-15 minutes. This will give the electronics time to reset themselves, if necessary.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
MY DEHUMIDFIER DOES NOT PRODUCT WATER. SOMETIMES THE COMPRESS KICKS IN BUT LATER I ONLY HEAR THE FAN RUNNING. IS THE COMPRESSOR BAD? SHOULD I GET A NEW DEHUMIDIFIER?
Since this one is faulty, maybe you should go ahead and get another dehumidifier because trying to fix this one will cost you a lot of money.
Dehumidifier repairs are quite expensive. |So you get a new one straight away.
Take care.
2answers
Will it cost me ?
Dehumidifiers2_bing.gif freezing up can be causes by a few different problems.
Here is a tip that I wrote to help people with the freezing dehumidifier2_bing.gif problem....
Dehumidifier is Freezing up and not working
http://www.fixya.com/support/r4662033-dehumidifier_freezing_up_not_working
heatman101
1helpful
Dehumidfier freezing up
heatman101
1helpful
Dehumidifier
IS THE ROOM HUMIDITY LOW. IF IT IS BELOW 30% THE HUMIDISTAT WILL SHUT DOWN THE UNIT. THE AMMBIENT TEMP SHOULD BE ABOVE 65 DEGREES AND THE HUMIDITY SHOULD BE ABOVE 50 %.
Top Dehumidifiers Experts
ADMIN Andrew
ADMIN Andrew
Are you a Dehumidifier Expert? Answer questions, earn points and help others
