The wire hinge is a weak point, and my Remington R4130 head also detached at the same point. Getting one side of the wire back into the hinge hole was easy, but to get the other side into the hole (located at the center of the back edge), I needed to use a needle-nose pliers to grab the bent end of the wire and direct the pointed end of the wire into the hinge hole.
SOURCE: what is the type of replacement head used for remington R-4130
You will require Remington SP-3141 replacement part. It is available at shaveroutlet.com. See link below.
http://shaveroutlet.com/remington-sp3141-flex-360-titanium-replacement-heads-p-591.html
Testimonial: "thanx !! thts really helpful information .. u saved so much time for me from the day thanx again"
SOURCE: I am looking for a replacement power cord for the
you will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/remington-charging-cord-for-r600-ms700-r4130.html
SOURCE: Do the replacement blades pack
You will find this head assembly with blades and holder at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/remington-spr-titanium-360-pivot-and-flex-replacement-heads-with-frame.html
