GE JTP15 Electric Single Oven Logo
A
Anonymous Posted on Dec 30, 2010
Error code F2 - GE JTP15 Electric Single Oven
espressonist
Level 3:
  • GE Master 1,711 Answers
  • Posted on Mar 09, 2011
espressonist
GE Master
Level 3:
Answers
1711
Questions
Helped
661932
Points
5029
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above 915F-930F
Look for welded relay contacts. If this happens, replace oven control (also
If no over temperature condition occurred:
Look for a high resistance connection or any other cause of high resistance in
the oven temperature sensor circuit. Check sensor, sensor harness and sensor
harness connection at sensor and oven control. Replace sensor if found
defective. Check door lock switches.
measures resistance of sensor circuit , not actual oven
temperature.
KitchenAid Range/Stove/Oven Model KGRT607HW4 gas range Error message F2:E5
Question edited for clarity. Please always include Maker and (what it is)'.
Mainboard control Issue. It can sometimes be fixed with a Power Reset.
F2 E5 - Electric Range - Product Help
KitchenAid https://producthelp.kitchenaid.com > ... > Starts with F2
Dec 14, 2019 - Power unit up by turning on the circuit breaker(s). Monitor the oven for one (1) minute to ensure the error code does not display again. Verify ...
Missing: KGRT607HW4 ‎' Show results with: KGRT607HW4
F2 E5 - Wall Oven - Product Help
I have a Kitchen Aid oven that is giving me an E5 and F2 and
JustAnswer https://www.justanswer.com > Appliance Repair
Aug 16, 2020 - Select the 'cancel' function and wait 60 seconds. If error code reappears then replace the touch pad, or touch pad and control board (clock) if ...
1 answer · Top answer: Manufactured August 2006. Your friend was correct. Only 14 years old
What are error codes E5. F2 - Q&A
Best Buy https://www.bestbuy.com > site > questions > question
Jan 17, 2019 - F2-E5 - Cancel Key Line Open - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Dec 17, 2023 • Ovens
1helpful
GE TrueTmp Oven. What is error code F2? The oven was off and wouldn't stop heating.
Runaway temperature over 590'F!
How to Fix GE Oven Error Code F2
D3 Appliance https://d3appliance.com > News and Tips
Dec 6, 2021 - A GE oven error code F2 occurs when the oven temperature is too high. Follow our comprehensive guide to diagnose and fix the issue.
My General Electric Oven Is Displaying The F2 Error ??
Express Appliance Repair Winnipeg https://www.expressrepairwinnipeg.ca > general-electri...
If any wires are exposed or damaged then your temperature sensor is misreading your oven's heat which causes the F2 error code. If you have found any damaged or ...
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.5 · ‎950 reviews
Missing: 326B1230P001 ‎' Show results with: 326B1230P001
How to Fix a GE Oven Showing Error F2
Hunker https://www.hunker.com > ... > Interior Home Repair
If you have a GE oven, the error code F2 on the oven means that the temperature sensor has detected a temperature in excess of the preset threshold.
Nov 25, 2023 • Ovens
Maytag model CWG3600AAB error code f2
There doesn't appear to be an F2 error code! There is an F1-2?
https://www.google.com/search?q=maytag+gemini+double+oven+error+code+f1-2&
There may be a problem with the Lower Oven Temperature Sensor, the Control, or the associated wiring.
Maytag - F1-2 - Product Help
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
1helpful
2answers
E1 F2 error code
Check the ribbon cable for connection
2answers
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
F2 error code
F2 E6 says this:
3. Replace control
3helpful
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
2helpful
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Top GE Ovens Experts
Paul Bade
Paul Carew
Are you a GE Oven Expert? Answer questions, earn points and help others
