Minolta Di3510 All-In-One Laser Printer Logo
Manojkoemar Rosan Posted on Dec 01, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Errorcode cof32 - Minolta Di3510 All-In-One Laser Printer
Anonymous
Level 3:
  • Master 1,110 Answers
  • Posted on Dec 01, 2010
Anonymous
Master
Level 3:
Answers
1110
Questions
Helped
554648
Points
4089
Imaging Unit calibration failure. This code means the machine is seeing a toner concentration in the Imaging Unit that is either to high or too low. This problem can only be resolved by a service technician. Salvaging the existing developer mixture is often not possible. The Imaging Unit will need the the developer replaced and calibrated via the service mode.
Good Luck and Thank You for using Fixya.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 26, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1199
Points
Hi i have a printer bizhub 163 so i have this code cof32 i need help me
Reset error code cof32 dialta minolta Reset error code cof32 dialta Minolta DI.1611 How to reset erro code cof32
Recommend you replace the drum and developer, after clearing the counters for them. Then then run the F8 procedure
Cof32
AT DC sensor abnormal please insert new developer
3helpful
Konica Minolta di1611 indicating cof32
ATDC sensor malfunction.Enter in the service mode :
press the Utility key press STOP 0 0 Stop 0 1
select CLEAR DATA then select I/C counter and reset the counter press C.to exit press panel reset.
Minolta 1501 errorcode COF32
Remove the black image unit and shake it so that the developer and toner inside of it is spread along the entire length of the image unit. reseat it install it correctly. if not get a new one
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
on what model machine?
Di350 error code cof32
Replace the image unit.
11helpful
Error code cof32
ATDC setting error - COF32, run F8 & use actual value, do not reduce setting value. open sie cover to reset.
20helpful
2answers
REMEDY TO SOLVING ERRORS COF32 AND CO650 IN KONICA MINOLTA BIZHUB 211.
to remove code "COF32" from your machine, simply change the developer with the new one. code will remove.
wish you best of luck............
17helpful
3answers
Code cof32
I removed Drum Unit, emptied excess toner, cleaned and installed. After short start-up code cof32 appeared.
Top Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
