5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
jorge serrano Posted on Nov 16, 2010
How to program my VIPER 5701 2-WAY ALARM w/REMOTE START
Anonymous
Level 1:
  • Contributor 42 Answers
  • Posted on Feb 10, 2011
Anonymous
Contributor
Level 1:
Answers
42
Questions
0
Helped
20853
Points
60
1. Open a door. (The GREEN wire, H1/8, or the VIOLET,
H1/6 must be connected.)
2. Insert the key. Turn the ignition to the ON position.
The heavy gauge pink wire must be connected.
Program switch corresponding to the number of the
desired function step listed in the following table.
Once you have selected the function step, press the switch once
more and hold it. The LED will flash and the siren will chirp to confirm
the selected functional step. Do not release the Program switch.
Step Function
1 Auto Learn Standard Configuration* (default)
The auto learn configuration will automatically setup the remotes button configuration.
Note: Due to the Supercode protocol, you cannot change the configuration.
2 Delete remotes: This feature will erase all remotes from the memory of the security
system. This is useful in cases when a customer's remote is lost or stolen.
Note:: This will not reset the programmed features of the security system or reset the
Virtual Tach setting.
3 Reset Features: This resets features all of the security system to the factory default settings.
Note: This feature does not delete the remotes from the security system or reset
the Virtual Tach setting.
4 Virtual Tach Reset: Deletes all previously learned values for Virtual Tach, and on the next
remote start sequence the unit will begin virtual tach initialization.
Note: The "Zap" feature on the Bitwriter will not reset the Virtual tach setting.
4. Transmit. While holding the Valet/Program switch, press
the lock button on the remote control. The unit will chirp
to confirm that the code has been successfully pro
grammed. It is not possible to teach a remote control but
ton to the system more than once.
5. Release. Once the code is learned, the Valet/Program
switch can be released.
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Viper 479V Viper Responder Remote how to program
open the door, turn the key on, press valet switch one time and press it again and hold it until alarm beeps if it dosent beep it means that alarm hasn't read the door open if it beeps press lock on the remote and it should beep again and its will be set. (if the alarm dosent beep you have to put the door trigger wire (green) to ground and repeat steps from beggining
1helpful
Viper 5701 led light does not flash when armed, stays lit when alarm is disarmed
If the LED is on solid then the alarm is in valet. To exit valet, press "F" twice then press unlock on the remote. The LED should turn off.
OR,
enter the vehicle, turn the ignition on then off, press and release the valet/programming button on the antenna. LED should turn off
I am trying to disarm the viper 5701 2 way alarm w/ remote start and the keypad nor is the manual override responding. How can I disable the alarm?
Get in car........alarm will be going offVisually find the black valet button..........it should be next to led on the antennaTurn key to IGN position...........so all dash lights are onWithin 5 seconds push the valet button 1 time..............may have been programmed to more times, but ussually notSiren should stop and you can start the car.
TO put into valet mode
Key to IGNKey to OFFPush valet button 1 time.Led should now be solid.
1helpful
11helpful
How to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
Kirk Augustin
Kirk Augustin
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
