Http://elektrotricks.blogspot.com/
http://electrotechnician.blogspot.com/
http://homenol.blogspot.com/
Please visit these sites to get some details.
SOURCE: Mitsubishi ws65611
If the caps on the DM board are not swollen on the top, they re ok, but if they are replace them.
SOURCE: DM module removal
Check this link for guidance with pictures about DM board removal.
Thank you.
SOURCE: 5 mostly green verticle lines on all digitle channels. HD ok.
I just called customer support and my issue is now fixed, to my extreme surprise.
It sounds silly (and a tad embarrassing), but here's what I did:
1) Unplug the TV
2) Wait 30s
3) Plug the TV in
4) Test
Apparently even if the TV is "off" for a few days it never fully shuts down unless the power is unplugged. Not sure if this will help anyone else, but I had the exact same problem others are describing. Good luck!
SOURCE: Replaced bulb 1 month ago, work fine, recently
hello,
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Have you studied your
manual on lamp replacement? See Here:
ehow.comreplace-bulb-panasonic-hdtv
as well as in your manual. Sometimes the
lamp must be reseated
by removing it and reinstalling it with great care
making certain
the door and all the gaps are closed tight.
If the lamp replacement or reinstallation does not
solve the
problem you will likely need a service tech to
look at the tv
as there are few user serviceable items for Plasma
sets. Most
of the repairs are done by computer connection
that downloads
the error messages and interprets what went wrong.
Hope this helps.
