Posted on Aug 19, 2010
Gestetner 6002 - Error Code SC542 - trying to bypass the error code to get into "system settings". Can you help me bypass the code to enter system settings?
5 Related Answers
Anonymous
  • Posted on Jun 23, 2008
SOURCE: Ricoh 1515 MF shows error code sc542
Um.. I don't see an "online" or "escape" button anywhere on the printer...
Anonymous
  • 37 Answers
  • Posted on Aug 14, 2008
SOURCE: Gestetner 6002?
you can down load a user manual for the machine at www.gestetner.co.za
M2Tech1
Andy Bell
  • 313 Answers
  • Posted on Jun 12, 2009
SOURCE: error code SC542, unable to clear message from
this is an error for the fuser heat up..the temp is not being maintained or fluctuations. try this press the yellow clear button at top of number pad then enter 107 and hold down the red cancel button..the screen will change enter the copier sp and select 5.mode arrow down to 5-810 sc reset and execute.turn machine off.. if the code disappears it could have been just a glitch if not check the fuser to see if there is heat coming from it the lamps will come on at te start up. you can check this by putting a screw driver in the actuator slot to cheat the door switch if you see the lamp come on then you may just have to clean off the thermistors .. open the fuser up with the top screws and check that there isnt any build up of toner on thermistors..hope this helps good luck A
Anonymous
  • 263 Answers
  • Posted on Mar 01, 2011
SOURCE: Gestetner 2212 copier Service Code SC542 I"ve
In your machine (model) you have to enter in SP mode to reset your error code.
Try this:
Yellow key.
1-0-7 on the key pad
Red key at least 3 sec.
Press "copy sp"
On the key pad press 5 810 and #.
Press execute
Exit all the way out.
Turn the machine off and on.
Anonymous
  • Posted on Sep 26, 2011
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
