Washing Machines Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error Code FL
I too have a kenmore elite calypso top load ...with an error code FL ...tub will not drain. What can I do?
Anonymous
Level 3:
  • Master 5,081 Answers
  • Posted on Jul 28, 2010
Anonymous
Master
Level 3:
Answers
5081
Questions
Helped
2276189
Points
18740
The FL (Over Fill) error code indicates that the flood pressure switch is open (tripped). It is likely that you are getting the LD (Long Drain) fault code because the control detects that the flood pressure switch will not reset after running the drain pump. Your likely failure is in the flood pressure switch
Tapping on the flood pressure switch with the handle of a screw driver may reset it. Reassemble the washer and see if it will work properly. If not, then you will need to replace the flood pressure switch. The part number for the flood pressure switch is 8054767. You can order this part from the Sears PartsDirect website. The part number for the flood pressure switch is 8054767.
  • Anonymous Jul 28, 2010
    FL
    flashes if any overfill condition occurs. This condition occurs when
    excessive water in the tub causes the overfill switch to trip. The
    control must realize that the trip was due to an overfill condition
    instead of a suds lack condition in order for FL to be displayed
    With an overfill condition, the beeper repeats a warning every 10
    seconds with no time-out. The pump is cycled in drain mode for 30
    seconds on, 30 seconds off until the overfill switch resets or power is
    discontinued to the unit.
    Press STOP/CANCEL to clear the display.
1 Related Answer
Anonymous
  • 171 Answers
  • Posted on Jul 24, 2010
SOURCE: error code FL and does not drain completly
most probably needs the water pump replaced.  not hard to do if you are a little handy..  there were a lot of problems with this machine regarding the water pumps.
vince
Pieter Vleeshouwers
Pieter Vleeshouwers
